Old 07-28-2019, 11:55 AM   #41
Jim Brierley
Default Re: Rear Axle Keys
I recommend driving around the block without installing the cotter pins after initial tightening, then re-torquing and installing pins. I do this 2 or 3 times.
Jim Brierley is online now   Reply With Quote
Old 07-28-2019, 07:26 PM   #42
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by 48fordnut View Post
Oh my gosh. So much about axle torque and nothing till no 37 finally answered the other mans question. I was looking for which way the taper goes up or down.
The taper faces IN and DOWN.
Tom Wesenberg is online now   Reply With Quote
Old 07-29-2019, 02:22 PM   #43
Pete
Pete's Avatar
Originally Posted by Bob C View Post
Self-Holding Tapers
Fig 2. Self-Holding Tapers
A special case for the beneficial use of friction is 'self-holding' Tapers (Fig 2) for easy machine/equipment component assembly and disassembly such as drill chucks and lathe tail-stock accessories.
A self-holding 'Taper' is an accurately machined tapering shaft and mating sleeve (both of which are dry and clean) that lock together using the coefficient of friction between the two surfaces (shaft and sleeve) and an assembly force (F). If the Taper is machined correctly, the same force (F) will be needed to separate the shaft and sleeve.
If the angle of the Taper is 'exactly right', the shaft or sleeve will be capable of driving the other with no additional assistance for light duty applications and yet part easily with no resultant damage to either of the mating surfaces.
It is important to remember that a plain self-holding taper is only capable of transmitting a force achievable from 'frictional' grip and is thereby limited in its driving capacity. For heavy duty applications the taper is usually provided with a key, the frictional grip providing the holding capacity only.
Read and understand the LAST paragraph in the above BobC's post #17.
Bt lapping the hub to the axle and getting a 100% surface, you can run WITHOUT a key in a STOCK model A application. It is NOT a heavy duty application. HOWEVER, it is near to impossible to get 100% surface on an axle and hub with machined surfaces that has been run/abused, corroded and pitted.
