Old 07-19-2019, 02:56 PM   #1
jimTN
Default rod bearings for 32-6 (flanged type)
This is a problem that all of us have who are working on the early 221". Is there a source for bearings other than std. I have been looking for some .10s and even the epay bin price is $500 +. There surely must be some vendors out there with a stock left. Any recommendations?
Old 07-19-2019, 05:16 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: rod bearings for 32-6 (flanged type)
To try on this site Fred Willner , Barnfind08 he tends to have a lot of the rarer bits.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 07-19-2019, 08:13 PM   #3
Brian
Brian's Avatar
Also try Chuck Kuntz, he has them in various sizes
https://www.fordbarn.com/forum/showthread.php?t=176983
Old 07-19-2019, 09:00 PM   #4
35fordtn
35fordtn's Avatar
Jim,
I’m in TN as well, what size are you looking for?
Old 07-19-2019, 10:48 PM   #5
Fordestes
I just sent you a PM., I found a set that are marked x10, also I have a slew of main bearings ,some still in cosmoline.
Fordestes is offline   Reply With Quote
Old 07-20-2019, 05:34 AM   #6
jimTN
Thank you all for the replies. I have a set coming from Fred. I may need mains yet, not sure if I have them in stock. Mike, I sent you a note thru epay right before I called Fred. I have more to do so this is all a big help.
