Old 12-07-2017, 09:38 PM   #1
Bruce Adams
Bruce Adams's Avatar
Default Mystery Starter Question
On Saturday my starter did not respond to the starter button AT ALL.
I Hit the "starter" with the headlights on and there was no dimming. I figured that meant the switch so I popped in a new switch and no change in results. I then popped the plugs and turned the shaft with my crank wrench with no particular restrictions.
I brought the starter to ANTIQUE FORD PARTS on Long Island and Bob Bader put six volts to it and it jumped to life.He felt it had jammed, causing the problem.
He returned it to me, I replaced the starter and it works perfectly for twenty starts in the past two days.
WHY, if it was BOUND, would the lights NOT GO DIM?
Thanks for your opinions
Bruce Adams is offline   Reply With Quote
Old 12-07-2017, 10:41 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Mystery Starter Question
If you’re SURE the lights didn’t dim, when the starter was engaged, then it wasn’t stuck. When you removed it , you should have noticed it was still engaged with the flywheel. Start checking connections. Do you have a electrical disconnect?
Old 12-08-2017, 12:22 AM   #3
eagle
eagle's Avatar
Bad spot on the armature can cause this. Jog the starter a degree or so and it'll take off...until it happens to stop again in the exact spot.
Old 12-08-2017, 09:03 AM   #4
Patrick L.
Patrick L.'s Avatar
I feel the same as Eagle.
Old 12-08-2017, 10:10 AM   #5
Jerry in Shasta
Jerry in Shasta's Avatar
Next time tap it with a hammer, old Chev trick or a stuck brush.
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 12-08-2017, 10:35 AM   #6
JBill
Could it have been just a bad cable connection somewhere that was corrected when the starter was removed and then reinstalled? I've haven't had that happen with my A, but twice with my lawn tractor!!
JBill is offline   Reply With Quote
Old 12-08-2017, 11:20 AM   #7
Bruce Adams
Thanks.
Neat idea but the lights tap off the same stud which was bright and tight, and they headlights stayed bright as day when I pushed down on the starter rod. They light a reflective sign at .3 miles.
A defective safety switch would not have permitted bright headlights, particularly when starter was "Engaged".
Old 12-09-2017, 10:46 AM   #8
JBill
Originally Posted by Bruce Adams View Post
Thanks.
Good luck finding the problem, and be sure to let us know what happens.
