Old 04-28-2017, 07:21 AM   #1
pookie55
pookie55's Avatar
Default 30/31 bango ring & pinion condition
As i'm not a pro at the model A differential i have a few questions for all the pro's on the barn..
First i had to brake down my truck's rear axle due to the right axle shaft thread's were not repairable(i tried).Axle nuts were only torqued down to 35 & 27 lbs. when i tried to re torque them-the threads just laid down.
For a mere $50. dollars i purchased the entire rear Bango assembly with drive shaft & complete drum/brake assembly.
Second when i removed the axle housing from the left side i found 3/4 in. thick grease in the bottom of the bango... upon further review and complete disassembly i see there is no axle drive shaft seals on either side(reason for grease in bango).also throughout axle housing.
Third do i need to replace the race & bearings while i have the rear apart?
Does the race have to be removed to install axle drive shaft seal??
Also the ring & pinion looks good to me. I did not want to remove the bango from the torque tube unless it was really necessary.
I'll post the pic's if possible or there in my truck parts pic's
pookie55 is offline   Reply With Quote
