12-16-2019, 01:37 AM | #21 |
Re: Running on 3 1/2
It will probably stay that way a while. Is there a hotter plug I can buy?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-16-2019, 05:03 AM | #22 |
I don't think a hotter plug is going to make a difference. A original style 3x plug maybe?
12-17-2019, 09:14 AM | #23 |
I have been thinking about the ports lately. If the oily plug is getting it's oil from past the rings, why would the intake port be all black and oily. Isn't that a one way path into the combustion chamber? With the 75 psi compression, the intake valve should be seating ok. The exhaust port was not oily at all. Seems it would be all oily if oil was pumping into the combustion chamber and with the fouled plug, not firing. Maybe I will do a vacuum test, or make up a leakdown tester from a take apart spark plug and a air fitting.
12-21-2019, 09:58 PM | #24 |
I did everything suggested on this thread.... Happy to say as of this morning it runs consistently on all 4. Proof is, it runs smooth and steady with 1,2 ,and 3 plug 'wires' removed... AND... I pulled the manifolds off a beater yard art A I have here, surfaced them and new gaskets again.... And it idles and runs so smooth! Was gonna have my wife do a video, but it got dark too soon. (duh, shortest day of the year) and we are going to the mainland tomorrow. Stay tuned Mon or Tues for a video with winch dragging a log and engine running like a champ. Thanks to you all !!!
12-22-2019, 06:14 AM | #25 |
That's great to hear. Oily intake port....on the compression stroke when the valve starts to close,some excess oil in the cyl. Is pushed or sucked back into the intake port. Why?... weak valve spring, worn cam lobe or valve way out of adjustment. (Very little lash)
This is all just a guess. |
12-22-2019, 12:13 PM | #26 |
Thread Tools | |
Display Modes | |
