11-11-2017, 04:47 PM | #1 |
Southwind Heater in a Model A Ford andy pics
I have read all the posts on the southwind heater but YET to see one installed in a model a..Does anyone have a pic of it. I have a NOS One with the bowl adapter for the fuel and considering installing but would like to see what others have done..
Thanks
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
11-11-2017, 07:56 PM | #2 |
Re: Southwind Heater in a Model A Ford andy pics
Hi Mark, I have a southwind in my 29 tudor. But it has been converted to a "hot water" heater. Coiled copper tube with electric fan. The car is stored right now, but can try to get pictures if you need. Jeff
Let's let pylons, be pylons! |
01-02-2019, 03:20 PM | #3 |
I had a Southwind in my '29 sedan. Mounted it to the angled top portion of passenger side floorboard as did not want to drill firewall. Worked great. It does not have to be mounted exactly vertical. Vacuum from WW port on intake.
As far as the pickup tube on the carb., just a little hole in top of the Tillotson did the trick. However I wanted to run my zenith carb. so fixed a U shaped tube to the drain plug on the bottom which ran upward alongside the carb and was higher than the fuel level. The pickup tube can be dunked in the top of that with a small dirt cap if needed. Used it for years without any problems. I lived in the cold northwest Iowa winters and drove it year round. Happy Heating Don Last edited by tubadon40; 01-02-2019 at 03:24 PM. Reason: additional thought. |
01-02-2019, 03:32 PM | #4 |
MSMARON, If the one you have with bowl adapter is the one intended for Lincoln Merc. carbs, you may have to obtain the (scarce) emulsion tube that came in most SW installs as the "fuel line kit no. 30". I have never seen the bowl adapter but believe the emulsion tube may be part of it. They will NOT operate without it and have not seen any reproductions.
01-02-2019, 09:48 PM | #5 |
My 30 Roadster used to have one installed but it was removed before I bought it. Holes are still there because I thought I might later install one. It was installed on the firewall just above the passenger feet.
I noticed the harder I work the luckier I get! |
01-03-2019, 08:53 AM | #6 |
