10-25-2014, 10:14 PM | #121 |
Re: Adjustable or Non Adjustable Lifters ?
I guess I stepped into that. Now that you have those very hard lifters, how much spring pressure are you going to put on them. for an L-100 I use 50 lbs for the street. You can ge this by putting a .o6o" shim under a stock spring.
Good luck |
10-25-2014, 10:36 PM | #122 |
I bought from that guy, after asking pointed questions about whether they were reground or what. He always maintained they were factory fresh, never in an engine. I had to pull mine after about 5,000 miles for other reasons, and none showed unusual wear. I'd be real curious what the game is. I can't believe "rejected Johnsons" were available to anyone at any point, with inadequate hardness.
'52 F-1, EAB flathead |
10-26-2014, 07:09 AM | #123 |
Right now I am building a 8N tractor engine for a collector, they take the same lifter as a flathead, the engine had been rebuilt back in the 50's, it had the original Johnson lifters, it was a pleasure to adjust those lifters, they all had same torque on the screws and I could adjust them with the original Johnson wrenches to hold the lifter. I haven't seen a good set since that place in Aostralier, spelling, stop making them. Walt
Thread Tools | |
Display Modes | |
