Old 09-25-2019, 09:44 PM   #1
Straw530
Default Model A Sputter
I just noticed the other day, that my Tudor has started to sputter. You can mainly feel it in high gear, lower speeds, but when going down the highway it seems fine. Also, at a stop sign, the idle speed now drops very low. Engine was rebuilt 1000+ miles ago, and I rebuilt the carb about 300 miles ago. It seems like it is getting fuel, although my first thought was that it was not. Thanks ahead for any thoughts
Straw530 is offline   Reply With Quote
Old 09-26-2019, 03:51 AM   #2
Wick
Wick's Avatar
Default Re: Model A Sputter
Check your point gap.
Wick is offline   Reply With Quote
Old 09-26-2019, 05:26 AM   #3
Jacksonlll
Jacksonlll's Avatar
Intake leak, probably at the intake flange to carb. Flatten both surfaces and use a new gasket.
Old 09-26-2019, 05:26 AM   #4
Straw530
Wil do. Thanks
Old 09-26-2019, 09:58 AM   #5
Mulletwagon
Mulletwagon's Avatar
Had same presentation which turned out to be a sluggish valve. Readily corrected with Marvel Mystery Oil.
Mulletwagon is offline   Reply With Quote
Old 09-26-2019, 06:29 PM   #6
Fred K-OR
Fred K-OR's Avatar
MMO like mentioned above, seemed to fix a similar problem I had.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 09-26-2019, 07:40 PM   #7
Straw530
How much did you run in the crankcase? I will also check the carb flange.
