01-17-2018, 03:18 PM | #1 |
Floor Board Support Iron Rivets
The Model A floorboards are supported by Support Irons. The Irons are secured to the wood floorboards with rivets.
Question, How to I "smash" or secure the the rivets to the back of the irons?. The heads of the rivets are on the wood. Would it be better to replace the rivets with fasteners? I have never worked with rivets. Thanks, |
01-17-2018, 03:47 PM | #2 |
Re: Floor Board Support Iron Rivets
Snyder's has the tool to set the tubular rivets RA-1017.
Bob |
01-17-2018, 03:49 PM | #3 |
The floorboard rivets should be semi-tubular. These rivets have a hole in the end that need peening with a semi-tubular rivet setting tool. What you need to correctly install the rivets is a semi-tubular rivet installation tool. The tool should be the correct size for the diameter if the rivet. The tool rolls the edges over. There are rivet gun semi-tubular rivet tool bits and hand tools. Hand tools work fine and you don't need a rivet gun for them. Below is a link to Snyder's semi-tubular rivet tools. All you need to do is insert the rivet, flip the floorboard over on a hard surface so the head is on a solid area and hit the tool with a hammer to set the rivet. A drop of oil helps make a nice "roll" on the peen.
Rusty Nelson http://www.snydersantiqueauto.com/tu...riveting-tools Last edited by wrndln; 01-17-2018 at 04:27 PM. |
01-17-2018, 03:57 PM | #4 |
Great!! Thanks guys!
01-18-2018, 02:10 AM | #5 |
A drop of oil on the tool always helps the rivet to make a nice clean roll over.
01-18-2018, 06:56 PM | #6 |
Thread Tools | |
Display Modes | |
