Old 03-31-2016, 10:58 AM   #1
clo
Default Distributor installation
I am installing a Mallory unilite distributor in a 59ab. There is no pointer or marks on the pulley. How do I know where the rotor is supposed to be facing so the motor will fire?
clo is offline   Reply With Quote
Old 03-31-2016, 11:13 AM   #2
JSeery
JSeery's Avatar
Default Re: Distributor installation
There are not any marks on the pulley on the 59a engines. Are you using the front mount distributor? The distributor mounts to the front of the camshaft and there is an offset slot it goes into. The distributor has a tab that goes into the slot. You have to be careful but you can force it in 180 degrees off. These distributor are set up off of the engine and then mounted.
http://www.vanpeltsales.com/FH_web/f...str-timing.htm
Old 03-31-2016, 11:39 AM   #3
clo
I am using a front mount crab style distributor. I'm just not sure when I pull the number one spark plug on the compression stroke, where is Tdc and where the rotor is supposed to face?
Old 03-31-2016, 11:47 AM   #4
34PKUP
34PKUP's Avatar
Should face to #1 position on the distributor cap.
34PKUP is offline   Reply With Quote
Old 03-31-2016, 11:55 AM   #5
JSeery
JSeery's Avatar
Why would that be important? You have to align the tab on the distributor with the slot on the camshaft. What cylinder is where is not an issue on these engines. If you needed to know where TDC was there would be an indicator for it, right? 8ba is a different process and you do need to align the crank pulley marker with the pointer on the timing cover, and guess what, it has the required marker and point. BUT, this is not how it is accomplished on a 59a or earlier engine.
Old 03-31-2016, 11:59 AM   #6
42 1/2ton
As JSeery indicated the distr. will only go one way due to the distr. shaft tab being offset.
42 1/2ton is offline   Reply With Quote
Old 03-31-2016, 12:08 PM   #7
clo
Got it. Thanks, for the info. It's much appreciated!
Old 03-31-2016, 12:10 PM   #8
JSeery
JSeery's Avatar
It's a fairly simple installation but so different from way most distributors are installed it's a bit confusing at first!
