Old 03-02-2018, 01:03 PM   #1
jacksonchuck
jacksonchuck's Avatar
Default 12 volt coil
Anyone know what car and what years 12 volt coil could be used without a external resistor? Converting an A to 12 volts and do not wish to use an external resistor.
jacksonchuck is offline   Reply With Quote
Old 03-02-2018, 01:11 PM   #2
modela4shane
Default Re: 12 volt coil
BOSH #00012 blue coil. Look on Amazon. They work great.
modela4shane is offline   Reply With Quote
Old 03-02-2018, 02:23 PM   #3
hardtimes
hardtimes's Avatar
I agree with the unsightliness of the external residtor on an A !
The way that I dealt with this 'problem' , is to use a 12V coil with an INTERNAL resistor (built into coil).
Been running coil this way for many years...no problem. Good luck.
hardtimes is offline   Reply With Quote
Old 03-02-2018, 04:04 PM   #4
Patrick L.
Patrick L.'s Avatar
Any 3 ohm epoxy filled coil should work
Old 03-02-2018, 07:07 PM   #5
AL in NY
AL in NY's Avatar
Check out the 3 ohm coils at First Street Ignitions. I would recommend an epoxy filled coil.
http://www.fsignitions.com/
AL in NY
AL in NY is offline   Reply With Quote
Old 03-02-2018, 11:32 PM   #6
Crankster
Crankster's Avatar
Not to be pedantic but ignition coils don't actually have a resistor inside them do they, but a resistance based on the number of turns in the primary winding?
There is so much confusion on the collector boards about ignition coils, they need to be measured between terminals so the user is certain of what he is installing. The resistance is what determines how much current (amperes) flows through the circuit.
Crankster is offline   Reply With Quote
Old 03-03-2018, 12:17 AM   #7
gustafson
you might be surprised what's inside a 12V coil
gustafson is offline   Reply With Quote
Old 03-03-2018, 12:34 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
According to hemming motor news "Coils come in four basic types, 6-volt or 12-volt and either internally resisted or externally resisted. Any coils that do not have an external resistor have one built into the coil itself. "
Old 03-03-2018, 01:13 AM   #9
updraught
updraught's Avatar
Which means it's dumping heat into the coil.
updraught is offline   Reply With Quote
Old 03-03-2018, 02:07 AM   #10
hardtimes
hardtimes's Avatar
It's all good Mike ! As the saying goes...you can lead them to water, but.......
Old 03-03-2018, 02:49 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Exactly..........and another good reason to stay with the original 6 volts.
Old 03-03-2018, 10:08 AM   #12
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
In this: http://cedarcreekas.org/TechTopics/1...rn_Signals.pdf
"Coil: you'll need to get a 12v coil with internal resistor. Again, available from the A vendors, although
I got a suitable one at the local parts house. Showed them the 6v coil and said “Match this size.”. They did. Turned out it was an Airtex coil 5C1019. A little sleuthing on the 'net revealed that it was used on several foreign cars, 1974 Volkswagen and 1975 MGB and perhaps others as well. This is a 12V coil with internal resistor, and it has worked very well for the past 2+ years I have been running it.
When I first made the coil change, I did not have Les Andrews' books. His recommendation is a UF-3
coil with internal resistor. (You really need to read Andrews' book. I did and it has helped immensely.)"
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 03-03-2018, 10:57 AM   #13
katy
katy's Avatar
My wife's 1961 Morris Minor uses a 12V coil, no external resistor.
Old 03-03-2018, 12:46 PM   #14
Apparently that is the Airtex coil 5C1019.
Bill Lee
Old 03-03-2018, 06:09 PM   #15
hardtimes
hardtimes's Avatar
He indicated that he didn't want to stay with 6 volt system and asked about help with 12V system..no ?
Old 03-03-2018, 11:37 PM   #16
Mike V. Florida
Sometimes it good to know the reason. Sometimes incorrect information is given and the new person thinks he HAS to make a change. Is this the case here, I don't know. When I do something new I like to know the good and the
bad and then make my decision.
Old 03-04-2018, 12:33 AM   #17
hardtimes
hardtimes's Avatar
Hey Chuck,
Did you get the help here that you were asking for ? If not please give more information so we can help you !
If you feel that you got requested/needed help, that is good to know.
BTW, I probably know of several reasons why an A owner may want to change from 6V to 12 V, but would you please give your reason(s) for changing ?
Old 03-04-2018, 08:35 AM   #18
jacksonchuck
The reasons for switching to 12 volt on my touring cars is to allow installation of air conditioning, use of modern 12 volt accessories(Nav, cell phone charger ,sirius radio, etc.), consistency with all of my other A's (have 6 - all 12 volt), easier to start (my opinion and experience), and easier to more safely jump start from or to a modern car.
Are there any domestic cars that ever used a 12voly coil without a external resistor?
Old 03-04-2018, 08:51 AM   #19
Deleted
Bill Lee
Last edited by BillLee/Chandler, TX; 03-04-2018 at 08:52 AM. Reason: Answered the wrong question
Old 03-04-2018, 11:01 AM   #20
Tom Wesenberg
OK, switching to 12 volts to add air conditioning makes sense. If you just need to charge or run cell phones and GPS, mine both work fine on 6 volts. Also you can buy convertors to change 6 volts to 12 volts. I bought one because I might use 12 volts on turn signals if I install some.
