10-31-2014, 04:14 PM | #1 |
A newbie in Model T world
I bought a 24 touring on e-bay last week. I have been into Model As forever, but have never had a T. Can you give me some good sage advice on the owning a Model T? I haven't never driven one, either.
Thanking you in advance................................... |
10-31-2014, 04:46 PM | #2 |
Re: A newbie in Model T world
Here's some reading to get you started:
http://dauntlessgeezer.com/DG52.html Pay special attention to First Parts and Thrust Washers. Here are some videos on starting and driving: https://www.youtube.com/watch?v=zCWn...tpDgCPJXbFCA6w https://www.youtube.com/watch?v=21k8...tpDgCPJXbFCA6w https://www.youtube.com/watch?v=lYhp8LWb6-w#t=19 |
10-31-2014, 10:34 PM | #3 |
They run better warmed up.
If you are running 6V on battery, a charging generator is a must. Start on battery then switch to mag if mag works. If mag does not work I removed the mag wire from the transmission mag post and hooked it to a 12v dry battery. Then you can start and run with switch in mag position. Starts easier and runs better. I did this for years until I fixed the mag. I too had/have an A for years before my 40 T years. Enjoy! |
11-01-2014, 12:38 PM | #4 |
Welcome WELCOME. I always recommend find a source for two books 'The Model T FordOwner by Murray Fahnstock and MODEL T Ford Service- reprint from Ford Motor. The main thing with driving is to understand that bands are not clutch plates. When we 'feather ' a clutch plate we make heat. Bands (unless they are Kevlar) do not like all that much heat. So the answer is to think about any automatic that is going to fail. The first thing notable is a slow shift (dirty fluid-clogged filter). This causes the bands to burn. The next step is a rebuild. Now carry this knowledge to the T planetary trans, and work the pedals with a clamping action. The quick grab of the band reduces heat build-up. The 'stab' of the pedal needs to be accompanied by the appropriate position of the gas valve. When starting off, as the slow pedal is clamped the gas valve is opened up quick to put power to the wheels. When going to high, time closing the gas valve briefly to allow the main clutches to lock-up then gas on. With downshift (say you're going up grade and it won't pull high gear) it helps to rev up as the slow pedal is clamped tightly. Next thought is to look into a trans filter if you don't already have one. A simple screen plate that will catch a lot of dirt and band material. Regular common gear oil that you can buy on any corner is not good to use in a rear that has babbit or brass. Look to the vendors for right stuff. Slow down or stop before going down any STEEP hill. Control your roll before gravity takes effect.
My dad was all about model 'A's. I even had a "Model A s Forever" button when I was a kid. As a 'grownup' I am pleased to say my "T" has taught me a lot. I'm glad I did not listen to all the A guys who said "you don't want a "T". Oh yeah, I love to read all the posts about which oil. NEVER graphite oil NEVER. It screws up the magneto. Other than that the 'T' likes anything as long as you change it frequently. Some say this, some say that, just remember, even if you have an air filter the oil will get dirty quick so frequent changes are best. And last I learned at an AACA conference as sometimes happens motors are not happy with available carburetion. When the power, on acceleration, is lacking try a quick sharp pull of the choke rod (up-down). This is a band-aid, but will get the roll going and ready to cruise.
Enjoy yer day. Tom Hate can't fix what it started. |
11-02-2014, 05:22 AM | #5 |
Thanks for all the sage advice!! I have to admit that I am a little anxious. I won't have the car for about three weeks.
11-02-2014, 09:22 AM | #6 | |
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
11-02-2014, 05:59 PM | #7 |
Tom your best bet is to locate a local club and find some one who is willing to show you the ropes. You're going to find out over time that the T is a totally different animal than the A. The only true way to drive it is hands on learning. Once that T second nature is learned it's a pretty good experience. I'm a quick learner but some one with knowledge could have been a huge help.
11-02-2014, 10:36 PM | #8 |
I agree a local club can be a big help if you're lucky enough to have one handy. Even without a club, you might find some nearby T folks to help out. But in many places you have to rely on MTFCA, Ford Barn, and Facebook. There may be Model T people in your area, but that doesn't mean they're active. A month ago we had a Model T tour here, with cars from Kansas, Oklahoma, Missouri, and Washington. It was free, with no registration fee. Of approximately a dozen Model T owners I know about locally, I was the only one who turned out for it.
11-03-2014, 03:12 AM | #9 |
Ditto: find a local Model T Club. T people are great and love to help out. I grew up with
T's and have been driving them for 50yrs. You're going to love it. I have two Model A's and four Model T's and love both. I think my blood pressure goes down every time I drive the T...... |
12-07-2014, 07:32 PM | #10 |
I have both T's and A's. They are different animals. Once you have the basics mastered, prepare to be addicted to these fabulous automobiles. I need a T fix at least 3 or 4 times a month, or I get depressed. In Michigan, our crusing season is short and I miss driving my T's more than any of my other collector cars. They are simply the biggest bang for the buck out there. Happy T'ing, you are going to love it.
12-07-2014, 09:54 PM | #11 |
Hey Tom--
How did this all turn out? Do you have the car yet? |
12-07-2014, 10:34 PM | #12 |
Tom, don't do what I did. I pulled into the shop in my new T and put the clutch in to stop. Not recommended! At least the brake was in the right place. PK
12-08-2014, 09:24 AM | #13 |
Tom, Welcome to Model T World from Fargo ND. I have owned my 23 Touring/Pickup since 1988 and I am still a newbie in an old chassis. I can' t add much to the sage advice others have given you to date. My only suggestion is that you start looking for the special tools you will need if you are going to service your 24 T yourself. You will find that Henry had a propensity to manufacture the T so that the only tool that would fit was a Ford or approved vendor. Three areas you can expect to need them is removing and replacing the carburator, R&R the generator, and adjusting the transmission bands, let alone Relining the bands. Modern tools just won't allow a proper job to be done. A word of caution there is Damned little room for fingers or arms either. I am a blood brother with my T a dozen ways or more, I learned French in the process as well. One final piece of advice Never Look At Fords Flat Rate Times to estimate the time required for a needed repair. In general if Ford allowed an hour I convert that to one day. Have fun, Dan Ph. #: 701-200-2319
12-08-2014, 09:48 PM | #14 |
Pat, I avoid that problem by backing in so I'm headed out the door when I leave.
What Dan said about the times in the manual is true for sure. Those times were intended for mechanics who got lots of practice working on these cars all the time. If you've installed new band linings a dozen times, maybe you can do it in forty minutes. But the first time it's more like four days. |
12-09-2014, 08:41 AM | #15 |
Steve, It's good to here that you and I are using the same conversion factor for Ford's Flat Rate. I have never been a fast turn out mechanic but I have always preferred Right to Fast. My first band reiine was 4 1/2 days working solo. I attribute the extra 1/2 day to the pictures I took of every step of the job including mistakes. Some day I will post them for everyone's perusal. Dan
