Old 06-19-2019, 09:17 PM   #1
Big Shark
Big Shark's Avatar
Default Windshield drain hose
Does anyone know who sells the hose that slides on the metal drain tubes at the bottom of the windshield frame for a 37 sedan? I looked at Macs, Drake, and some others. No luck. Thanks Bruce
Big Shark is offline   Reply With Quote
Old 06-19-2019, 09:47 PM   #2
TagMan
Default Re: Windshield drain hose
As I recall, the hoses are 1/4" I. D. and are thin wall, black rubber. Buy at any auto parts store.
TagMan is offline   Reply With Quote
Old 06-19-2019, 09:47 PM   #3
JSeery
JSeery's Avatar
Think that is something you would buy local.
Old 06-20-2019, 11:58 PM   #4
bill3337
bill3337's Avatar
Yep, I used clear tubing on mine, available in many places.
bill3337 is offline   Reply With Quote
Old 06-21-2019, 12:00 AM   #5
Tinker
Tinker's Avatar
As others have said, it's tubing. vacuum tubing looks correct and works. Napa or others have bulk.
Old 06-22-2019, 09:27 AM   #6
325w
Radiator overflow tubbing is thin wall. Most auto stores only have it in 2-3 ft. Lengths. Get two and go by the vacuum fittings and get a splice to make it longer
325w is offline   Reply With Quote
Old 06-22-2019, 02:59 PM   #7
TJ
TJ's Avatar
Make sure that the metal drain tubes in the body are good and clean. In the past I have found them to be plugged up.
