09-13-2018, 10:27 PM | #1 |
Model A clutch
Is there a source for model A clutch parts. I have one that is in real nice condition however it appears the throw out bearing must have had issues as the fingers are worn excessively. Are new finger available.
Daren |
09-14-2018, 02:03 AM | #2 |
Re: Model A clutch
While driving, there should not be contact between bearing and fingers.
Make sure you have some free play in the clutch-pedal before there is some drag. I doubt you will find new fingers to fit your plate. I got 3 (Model-A) pressure-plates and all parts are different (not interchangeable) Get a new throw-out-bearing, a new pressure-plate and follow Tom Endys suggestions Have fun Chris |
09-14-2018, 08:05 AM | #3 |
Re: Model A clutch
You "might" get a lead by calling a local Truck Repair Shop & ask, "Who rebuilds your CLUTCHES"?
Bill Smooth
09-14-2018, 01:52 PM | #4 |
Re: Model A clutch
What Bill said. Frequently small parts of assemblies are only available to rebuilders who have accounts and stock parts.
09-14-2018, 02:15 PM | #5 |
Re: Model A clutch
Berts in Denver will have many good used ones..
09-14-2018, 03:31 PM | #6 |
Re: Model A clutch
There not that expensive. |
09-14-2018, 03:44 PM | #7 |
Re: Model A clutch
I recommend Bratton's for clutch replacement parts. They have the disc with the tabs that hold the springs in place. The other venders do not. https://www.brattons.com/clutch-disc.html
09-14-2018, 05:39 PM | #8 |
Re: Model A clutch
Fort Wayne Clutch or any of the above.
Paul in CT |
09-14-2018, 06:15 PM | #9 |
Re: Model A clutch
Ditto as to Fort Wayne. They have the proper spring shrouded disc.
09-14-2018, 07:53 PM | #10 |
Re: Model A clutch
I don't know, the one in their picture doesn't look like it...
09-14-2018, 11:24 PM | #11 |
Re: Model A clutch
I have NOS Genuine Ford Model A Clutch disc and pressure plate. $75.00 plus the ride.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
09-15-2018, 12:41 AM | #12 |
Re: Model A clutch
change the pilot bearing as well.
