Old 03-18-2017, 05:36 PM   #1
oz40
oz40's Avatar
Default Accelerator pedal Question.
Is the 1935-48 sedan accelerator pedal one and the same part # ?
Or what years are corresponding? TIA.
oz40 is offline   Reply With Quote
Old 03-18-2017, 06:56 PM   #2
40cpe
40cpe's Avatar
Default Re: Accelerator pedal Question.
I can't say for sure, but I put one from a '40 in a '38 and had to do some chiseling in the wood floorboard to get enough travel. But the floors are aftermarket, too. The contour of the firewall is different in that area so I suspect a slightly different bend at the accelerator end.
Old 03-18-2017, 08:04 PM   #3
rich b
rich b's Avatar
There are different pedal assys; the bends vary on the pedal side; thought I had a link to some info; but can't find it right now.
Old 03-18-2017, 09:49 PM   #4
Bob C
The green book shows 1935-48 LHD passenger 8cyl are the same.
Don't know about RHD.
Bob
Old 03-19-2017, 07:56 AM   #5
Andy
The original production 35-36 pedals were different but the later pedals were the same dimensions and were the replacement 35-48. I don't know about RHD.
Andy is offline   Reply With Quote
Old 03-20-2017, 03:28 AM   #6
oz40
oz40's Avatar
Hi Bob,, I have a part number 91A -9725,, from an earlier internet sale advert. Bob, from the Green Book info does it correspond up to and including the 48.?
I had a aussie 1940 RHD accelerator assembly as well as a LHD version,, they are mirror opposites.
The reason for my research, is that trying to get a 1940 assembly is getting harder down here as there are not many 40's around, so if the part was carried over ,, I then can get one out of a local 41-48. thanks..
Bob
Old 03-20-2017, 03:36 AM   #7
oz40
oz40's Avatar
Hi Andy,,, thanks on the reply also,,, I just replied to a previous post, (Bob), about the actual part number,, but it appears to be 1939 reference.
As mentioned its hard getting 1940 stuff down here, because of very limited supply.. So if the part number was a carry over I can source from other later years..
I have a few 35/36 accelerator assemblies but these have the spoon end on them...
Our assemblies are basically a mirror opposite of the LHD versions..
cheers.
Old 03-20-2017, 11:21 AM   #8
Bob C
Parts book shows 91A-9725 is for 1935-48 passenger 8cyl.
Bob
Old 03-20-2017, 12:02 PM   #9
Andy
I can't figure out what a right hand assy would look like. Is the pedal on the right? Confusing. I have made assembly's by cutting and bending. The spoons are easy to make from plate and a little rod and a linkage end and you are set. I wish I could offer a pic of what you need.
Old 03-20-2017, 04:55 PM   #10
oz40
oz40's Avatar
Here is pictures of a 39 and 40 aussie firewall with the assembly.. Sorry about the quality of the pictures.. As you can see ours are the same but mounted over on the right.
