Old 09-10-2019, 07:27 PM   #1
vern hodgson
Default Shade tree test
If alternator is working, should I be able to remove one battery terminal and the motor will continue running on the alternator output?
vern hodgson is offline   Reply With Quote
Old 09-10-2019, 07:39 PM   #2
holdover
Default Re: Shade tree test
yes, but it will not give you an idea of its true output. It doesn't take much to work the ignition system.
holdover is offline   Reply With Quote
Old 09-10-2019, 09:39 PM   #3
eagle
eagle's Avatar
A decent quality voltmeter will tell you volumes about the condition of the charging system and battery. Check battery voltage before you start the car, engine running at idle speed, engine RPM at cruising speed, and after 10 minutes of cruising speed RPM.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 09-10-2019, 09:50 PM   #4
Railcarmover
yes,but make sure the alternator is internally regulated.
Railcarmover is offline   Reply With Quote
Thread Tools
Display Modes
