08-18-2019, 12:33 AM | #1 |
fuel economy
I have noticed these last few trips away in our 33 the fuel usage has gone up,
it used to be able to manage 18 ltrs per 100 klms easily,but has lately been all over 20L / 100. So I did a bit of searching in my log books, found that it changed in mid 2017, same time I had changed the cylinder heads,one of witch had a small crack, these were 75cc in the chamber. the ones I fitted were 82cc in the chamber,( only ones I had) nothing else had changed. I had looked out for another set but to no avail, so I will repair the small crack and refit the 75cc ones. Side note, the 33 just did the trip to the Mt Isa rodeo and back, great trip.around about 2000 miles .used no oil, Lawrie |
08-18-2019, 03:24 AM | #2 |
Re: fuel economy
There are other factors beyond your control that affect fuel economy: The formulation of fuel of late is done for political advantage rather than for the efficiency of the engine.
Alan |
08-18-2019, 04:01 AM | #3 |
Re: fuel economy
Getting less power from each liter of fuel, as happens when lowering the compression ratio, will lead to more fuel being necessary to accomplish the same work value. I am somewhat surprised there was not a noticeable increase in radiator coolant temperature also?
08-19-2019, 04:53 AM | #4 | |
Re: fuel economy
Lawrie - Those figures round town or on a trip? By my calculations 20l/100km is about 14mpg (imperial) . On my last trip over 1800 miles we averaged 20.5 mpg but round town its probably round 16mpg . -However I suspect you were towing your trailer ?? Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
08-19-2019, 10:22 AM | #5 |
Re: fuel economy
