11-11-2013, 01:08 PM | #1 |
Exhaust for an 8BA
I am getting ready to replace the exhaust on my 36' pick-up. It has an 8BA in it currently. Based on what I have read, I will be putting 1 3/4" tubes underneath. I would like to replace the exhaust pipe flanges and have not been able to turn up any with 1 3/4" holes. I have checked the usual suppliers and local shops do not have them. Any suggestions? Do I need to fabricate my own? 2" flange with a reducer? Any information would be a great help.
11-11-2013, 02:15 PM | #2 |
Re: Exhaust for an 8BA
Try Reds Headers...
Karl |
11-11-2013, 03:55 PM | #3 |
Am assuming that when you say "the usual suppliers" you did not check NAPA.
If not would this suffice? http://www.napaonline.com/Catalog/Ca...881_0399280374
11-11-2013, 04:10 PM | #4 |
Checked the Red's website, plenty of gaskets but no metal flanges. It was worth a try. First, I go around to the shops that I know of and see if I can get what I need over the counter. When that fails, I look on the web and see what I can get shipped to me. There is no Napa near to me, this will have to wait till I can go up to San Francisco. Is there much difference in going to 2" tubes? There seems to be a bit more to draw from if I go that way. It's only a 1/4" difference. In other threads here on the barn I have read about using 1 3/4" for exhaust. The old ones on my truck are this size or smaller. Just wondering.
11-11-2013, 04:34 PM | #5 |
would this 1.75" roll bar tubing flange work:
http://www.ebay.com/itm/Tubing-Flang...-Tube-FO5304A- Description: Tubing Flange Mount for Cage 1.75" Tube FO5304A This flange is based on our FO5304 flange and shares the same dimensions. The mounting holes are 3/8" diameter, placed 3" apart. It is laser cut from 1/4" steel. The part number is FO5304A. Price is right and no petrol on your part is required. |
11-11-2013, 04:38 PM | #6 | |
Besides that 2" gives the added advantage of less restriction. Go for the 2"
11-11-2013, 04:40 PM | #7 |
I have 2" on mine ...
11-11-2013, 05:09 PM | #8 |
2" on mine too. No 1 3/4" Smithy's at Summit.
Gene |
11-11-2013, 08:15 PM | #9 |
Thanks for the information. Like anything, it's all about availability. I spent some time looking for 1 3/4" flanges with no luck. Thinking I can cut off the ones I have and grind them to take a weld. If that won't work I will make them out of stock. If it was easy, everyone would do it.
11-12-2013, 07:52 AM | #10 |
When replacing a 59a with a 8ba in 47 ford car, if I use 47 manifolds will they bolt up if lucky, or how close will they be.
11-12-2013, 08:39 AM | #11 |
11-12-2013, 10:12 AM | #12 | |
11-12-2013, 11:35 AM | #13 |
Hi Walt
I just got me another car 47 ford its rappes louded then mufflers. 59a engine. I picked up a 8rt out of truck. wanted to know if pipes would bolt up with no problem. Could you do a rebuild this winter on the 59a engine. |
