Old 05-19-2019, 05:22 AM   #1
flathead 53
Default Stromberg 97 or holley 94
Pros and cons of both carbs , what carb is better for a 1949 to 53 flathead ,speedway sells the super 97 for $299.00 about the same cost for a holley 94 , what is the opinion on both.
flathead 53 is offline   Reply With Quote
Old 05-19-2019, 06:06 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Stromberg 97 or holley 94
First whatever carb you buy needs a venturi vacuum port to work with the original distributor...
I like the 94 since i can tune it for better economy then the Stromberg...downside is you need to understand how to tune the vacuum part if going for a non stock setup.
If its for a stock engine the 94 should work just fine !
Old 05-19-2019, 07:32 AM   #3
flathead 53
the engine in my 53 f-100 is a stock 51 mercury flathead , It has a new 94 carb on it ,only mods on engine are tube headers and smithy glass packs.
Old 05-19-2019, 08:48 AM   #4
uncle max
uncle max's Avatar
If your friends are buying Speedway carbs, get new friends.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ info@97-express.com
uncle max is offline   Reply With Quote
Old 05-19-2019, 08:51 PM   #5
Talkwrench
Talkwrench's Avatar
gold Max!
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 05-19-2019, 09:14 PM   #6
Tinker
Tinker's Avatar
I have a very good friend that used a speedway super.
Granted I do use an new english97 and have had and run some other old 97s rebuilt by a local race guy. Both earlier flatheads then yours.
As mentioned, your carb choice is determined by your distributor choice. I like the 97s a lot. But not what you might need.
Old 05-19-2019, 09:45 PM   #7
cas3
yup, good one max! hey tinker, i thought you were a 94 kinda guy?
Old 05-19-2019, 09:49 PM   #8
Tinker
Tinker's Avatar
Nope. 36 was a 97. 38 was first yr chandler "94" (now a 97). Nothing wrong with the 94.
Old 05-20-2019, 05:09 AM   #9
flatmotor40
flatmotor40's Avatar
I've been running Super 97 from Speedway for some 10 yrs and no problems
flatmotor40 is offline   Reply With Quote
Old 05-20-2019, 11:47 AM   #10
Russ/40
Russ/40's Avatar
After the correct powervalves became unobtainable awhile ago, i decided to try a very nice Stromberg48 i had on my bench for years as garage art. The 40 ran so good, I never took it off. Been years running the 48 carb. Most trouble free carb I have ever ran.
Russ/40 is offline   Reply With Quote
Old 05-20-2019, 07:20 PM   #11
RalphM
RalphM's Avatar
Im kinda partial to the Chandler Groves carburetors myself, although I do own a couple 97s.
File Type: jpg 08B9F381-9F20-422A-8307-16E8B01167B5.jpg (46.8 KB, 39 views)
RalphM is online now   Reply With Quote
Old 05-20-2019, 11:30 PM   #12
Tinker
Tinker's Avatar
Nice setup.
Old 05-21-2019, 12:46 AM   #13
Newc
Newc's Avatar
Hi all; Just a note about the 94 style. Found another rebuilder mix/mash 94. It had the external float vent top on a 'rt' base. Those external vent tops are for crank mounted fan engines only I understand. ??? Went down the '40 concourse line at Salem Western Nats and saw a variety of carb tops. Newc
Old 05-21-2019, 07:24 AM   #14
my2nd40
my2nd40's Avatar
Why would anyone, for any reason, ever buy a carburetor or ask for advice from anyone but Max?
He is the final answer on these carbs.
my2nd40 is offline   Reply With Quote
Old 05-21-2019, 12:37 PM   #15
scicala
scicala's Avatar
Probably because there are actually other people out there that can do quality work also. I agree that Max does have the best reputation on 97's.
Sal
Thread Tools
Display Modes
