Old 04-25-2016, 08:16 PM   #1
oldbird55
Default prep lead seams
How do you prep lead seams on a baby bird. I've herd about some type of acid treatment that stops the paint from bubbling over time.
oldbird55 is offline   Reply With Quote
Old 04-25-2016, 08:51 PM   #2
miker98038
miker98038's Avatar
Default Re: prep lead seams
Eastwood carries lead supplies,,tools, etc. if you go over to the HAMB, and run a search, you'll get more info and opinions than you ever wanted. When you find the answer, post it back. I need to know for my bird one of these days.
miker98038 is offline   Reply With Quote
Old 04-26-2016, 07:32 AM   #3
frank long island
frank long island's Avatar
With the fillers of today why use lead remember body filler won't stick to lead unless it is primed i prep and apply epoxy primer
frank long island is offline   Reply With Quote
Old 04-26-2016, 08:36 AM   #4
Ford blue blood
Ford blue blood's Avatar
Clean, clean, clean, 40 grit paper, epoxy primer, urethane primer, and "surface leveling" material.
Bubbling of paint is almost 100% incomplete cleaning.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 04-26-2016, 09:08 AM   #5
Oldmics
I have run into rust behind the lead seams.
The lead looks great on a frontal view but once you remove the lead,then you will find all sorts of rusty horror underneath those seams.
As previously mentioned - with todays new polymer technology there is no need to use lead. The new stuff is better!
Oldmics
Oldmics is offline   Reply With Quote
Old 04-26-2016, 09:29 AM   #6
Ole Don
Ole Don's Avatar
Buy a can of metal prep, read the small print. Use rubber gloves. Put it on, let it sit, but no long enough for it to dry completely. Put more on, wash it off and dry. Do only a big enough spot each time so nothing dries until you dry it. Bare metal will turn a color. This is the last thing to do before you spray epoxy primer. Don't touch it, and don't let it get dusty.
Ole Don is offline   Reply With Quote
Old 04-26-2016, 06:39 PM   #7
mikhett
A lot of epoxy primers are not compatible with acid treatments.ASK ME HOW I KNOW.
mikhett is offline   Reply With Quote
Old 05-27-2016, 11:00 PM   #8
36 flathead
If you need to remove flux residue from lead you can wash with 50 50 mix of alcohol and ammonia. Or backing soda and water. I prefer alcohol and ammonia , less chance of rust.
36 flathead is offline   Reply With Quote
