04-25-2016, 08:16 PM | #1 |
prep lead seams
How do you prep lead seams on a baby bird. I've herd about some type of acid treatment that stops the paint from bubbling over time.
04-25-2016, 08:51 PM | #2 |
Re: prep lead seams
Eastwood carries lead supplies,,tools, etc. if you go over to the HAMB, and run a search, you'll get more info and opinions than you ever wanted. When you find the answer, post it back. I need to know for my bird one of these days.
04-26-2016, 07:32 AM | #3 |
Re: prep lead seams
With the fillers of today why use lead remember body filler won't stick to lead unless it is primed i prep and apply epoxy primer
04-26-2016, 08:36 AM | #4 |
Re: prep lead seams
Clean, clean, clean, 40 grit paper, epoxy primer, urethane primer, and "surface leveling" material.
Bubbling of paint is almost 100% incomplete cleaning.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
04-26-2016, 09:08 AM | #5 |
Re: prep lead seams
I have run into rust behind the lead seams.
The lead looks great on a frontal view but once you remove the lead,then you will find all sorts of rusty horror underneath those seams. As previously mentioned - with todays new polymer technology there is no need to use lead. The new stuff is better! Oldmics |
04-26-2016, 09:29 AM | #6 |
Re: prep lead seams
04-26-2016, 06:39 PM | #7 |
Re: prep lead seams
A lot of epoxy primers are not compatible with acid treatments.ASK ME HOW I KNOW.
05-27-2016, 11:00 PM | #8 |
Re: prep lead seams
If you need to remove flux residue from lead you can wash with 50 50 mix of alcohol and ammonia. Or backing soda and water. I prefer alcohol and ammonia , less chance of rust.
