Old 09-28-2014, 11:37 PM   #1
impala58
Question installing choke and throttle cables in 39 Deluxe
Howdy
Does anyone have a diagram or knows any tips how to put
together the links and knobs for the choke & throttle cables coming
Through the dash on a 39 Deluxe? I got the parts from Mac's
But haven't figured out how they go together yet!
any help will be appreciated
Thanks
Mike
impala58 is offline   Reply With Quote
Old 09-29-2014, 12:50 AM   #2
Kahuna
Kahuna's Avatar
Default Re: installing choke and throttle cables in 39 Deluxe
Mike
Do you mean the choke and throttle RODS?
Kahuna is offline   Reply With Quote
Old 09-30-2014, 11:49 AM   #3
39topless
Originally Posted by impala58 View Post
Howdy
Thanks
Mike
Mike, The shorter rods with the bends attach to the knobs on one end and the other end goes through the firewall. The longer rod, with the quick release fitting, attaches to the shorter (bent) rod using the black rubber coupler. The quick release attaches to the carb lever. As I remember, the longer two rods will be slightly different lengths but the bent rods should be the same. Email me at 39topless@gmail.com and I will send some pictures.
Phil
39topless is offline   Reply With Quote
Old 09-30-2014, 05:08 PM   #4
Kube
Kube's Avatar
If you have an early '39 with cables, the repop knobs will not accept them. The repop knobs are for the later, rod type linkage. You will need to locate NOS knobs designed for the cables or modify repops.
Kube is online now   Reply With Quote
Old 09-30-2014, 05:43 PM   #5
Charlie ny
Kube knows...............huge difference between early and late '39's !
Charlie ny
Charlie ny is offline   Reply With Quote
Thread Tools
Display Modes
