Old 08-31-2018, 07:23 PM   #1
GAR64
Default Starter Switch?
Ok, so I did a search and found threads about starter issues. Seems like my starter switch is bad. Starter sometimes remains spinning after car starts. Also, starter sometimes keeps cranking even if I release lever (I have one of those hand levers instead of foot button). I do have a shutoff, but when I turn back on, of course it starts cranking again. I can see that the switch rod does release when I release lever, so it guess it is an internal contact issue?Could it also be a problem with the starter itself??
GAR64 is offline   Reply With Quote
Old 08-31-2018, 10:31 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Starter Switch?
Most likely a weak or burned contact spring. I use a good strong original spring contact, even if I need to restore the housing. File away any rough or burned areas.
Old 09-01-2018, 02:37 PM   #3
Jacksonlll
Jacksonlll's Avatar
Take the switch off and fix it. Not much in there. Most new ones are good if you need it.
Old 09-01-2018, 07:02 PM   #4
GAR64
Thanks for the replies. I think I will order a new one. Looks fairly simple to replace.
Old 09-02-2018, 02:55 PM   #5
john in illinois
john in illinois's Avatar
I would follow Tom's advice and find a used original Ford switch. The new ones are junk. Spring is soft.
John
john in illinois is offline   Reply With Quote
