04-11-2015, 07:48 AM | #1 |
Bob Drake has new radiator hose kits for '32-'36 with '37-'48 engines
This is something that has been needed for some time. Many had found a one piece Gates hose that fit '35-'36 cars with the later engine. Bob's new offers covers many other combinations.
https://www.bobdrake.com/Categories2...a-79e2496fcc62
04-11-2015, 08:06 AM | #2 |
Re: Bob Drake has new radiator hose kits for '32-'36 with '37-'48 engines
You know Bob will not get rich overnight with this and will take time to recoup his investment.
The opportunity has been there for years for these hoses and no one has stepped forward with the ging to make it happen till now. My hat is off to Bob !! |
04-11-2015, 10:26 AM | #3 | |
Lineman, the only dumb animal that can harness himself !! |
04-11-2015, 10:42 AM | #4 |
The Ford Pilot top hoses fit perfect... but hard to get
04-11-2015, 11:02 AM | #5 |
This is an excellent addition, was a coincidence that I was looking for a new set.
04-11-2015, 11:22 AM | #6 |
04-11-2015, 11:52 AM | #7 |
The 32 hoses for an electric fan look just like what is on my car. I am using 21A uppers and 8BA lowers. They come with supports/guards even and Ford scripts.
08-08-2017, 01:03 PM | #8 | |
https://www.bobdrake.com/FordItem.as...4-102cbf996a91 Would like to hear from someone with personal experience. Thanks, Neal |
08-08-2017, 05:12 PM | #9 |
There was an earlier thread on this subject. See: https://www.fordbarn.com/forum/showthread.php?t=51117
The set up pictured is similar to what I used on my '32 with a later flathead. The pictures in that thread show the use of the 59A type fan. I have the original '32 fan mounted on the generator and it clears the hoses. The Bob Drake hoses have a similar shape, so they may work. |
08-08-2017, 07:29 PM | #10 |
Used them on the 59AB in my '32.
Clearance is close between generator mounted fan and upper hoses (1/4"), so not much adjustment. I switched out to a PowerGen with same fan and clearance stayed the same. Took 53-1/2" Gates belt. |
08-08-2017, 11:45 PM | #11 |
I have those hoses in my 32 5w with stock fan. Pictures in my public album of 5w. They fit really well.
08-09-2017, 06:20 AM | #12 |
That link says I need to sign in or create an account to proceed.
08-09-2017, 07:49 AM | #13 |
1932-48 CARS & 32-47 TRUCKS1935-36ENGINE ( FLATHEAD ), DRIVETRAIN & MECH
Radiator Parts section: https://www.bobdrake.com/3536flathead-radiatorparts $60 |
08-09-2017, 12:44 PM | #14 |
Wow! I have been looking for hoses to replace the flex hoses (yucky) on the 59AB engine in my '36 for years. I just ordered a set of hoses from Drake.
Bill.... 36 5 win cpe |
08-19-2017, 11:19 AM | #15 |
Received my Drake retro hoses in the mail yesterday. Very nice items, rubber side walls are quite thick, hopefully they wont droop to much over time.
Reviewing the situation in my engine compartment with the stock (dual) '42-48 coils for my Harmon-Collins ignition, attached to a stock Ford coil mount on the left front of the engine, I might have a clearance problem. It appears that the clearance on the side mount generator will not be an issue. The offset in the lower hoses is a nice touch. Putting the lower hoses on is a real chore with the later engine. Without the offset you have to use new hose and kink it to get it onto the water pump.
08-27-2017, 05:09 PM | #16 |
I bought a set of the Bob Drake hoses for a 32 with later flathead. We did a mockup in the 32 pickup I'm working on, and they do fit well and clear the original fan. Just thought I'd follow up.
08-28-2017, 10:17 AM | #17 | |
Also, those old school flexible hoses shown above in blucars post can exert enough force on the radiator inlet tubes to either fracture the tubes or their solder connections to the upper tank.
08-28-2017, 10:50 AM | #18 |
Guess it's a matter of prospective, I like the chrome or stainless tubes better.
08-28-2017, 11:54 AM | #19 | |
I have a nice set of chrome/stainless pipes, 4 curved rubber hoses, and 8 hoses clamps that I made up for my 35 hot rod project with 59a engine that have never been used if anyone wants them at less than my original cost. I wound up using Gates one piece rubber upper hoses. Look much better, but again, JMO
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 08-29-2017 at 05:59 AM. |
