01-21-2020, 05:26 PM | #21 |
Re: Looking for exhaust port layout drawing
WOW. 14 posts do do something this simple?
01-21-2020, 06:18 PM | #22 |
15, i thought they are 45* ?
01-23-2020, 05:38 PM | #23 |
16. Made a template off the block at the machinist's shop. You know engineers have to complicate everything. 😏
01-23-2020, 06:46 PM | #24 |
You only need the outer holes so they will do for both sides.
01-23-2020, 07:05 PM | #25 |
Got it. We checked the other side of the block and the outer holes lined up as you said, but I can almost guarantee that I would have drilled out the middle holes, so thanks for reminding me.
01-23-2020, 08:06 PM | #26 |
01-23-2020, 08:42 PM | #27 |
Yep. After playing around with some printer paper and a pencil, that is exactly what the machinist did, instead just with a heavier piece of cardboard and no hole punch.
01-23-2020, 08:47 PM | #28 |
Cool. I like to use the aluminum sheet because the holes "don't move" if you have to use it again.
01-23-2020, 11:18 PM | #29 |
If it were me, I'd clamp an exhaust manifold on the piece of steel I was going to use and using transfer punches mark the holes and them take them to the drill press. Why go to all the trouble of making a template, then transferring those marks to your steel? You have a couple of chances of having something move and be off.
Or if you really wanted to make it complex, create a DXF file and take that to a CNC mill or a laser cutter! |
01-23-2020, 11:47 PM | #30 |
He does not have a manifold, that's what started all of this.
02-03-2020, 08:33 PM | #31 |
Finished off the adapter. Fits great. I just had to trim the corner like in the previous pics, and cut down my 1.25" lg bolts to 3/4". Yes, I lifted with only two manifold bolts and a chain. Lol.
02-03-2020, 08:58 PM | #32 |
Looks great!
02-04-2020, 04:00 AM | #33 |
Only two manifold bolts?
A bit lavish ain't ya? One would have done. |
02-04-2020, 04:47 AM | #34 |
LOL. True, but that's what the machinist used. He suggested I make a plate to cover the intake with a couple lifting points which I'll do soon. First, I want to get a dial gage and fixture so I can mark TDC on my pulley, which I may need to purchase as mine is some cobbeled up affair with a third groove crudely welded on.
02-04-2020, 11:27 AM | #35 |
this one is a bit elaborate, but i hope to use it until my toes point up. cut out to match an intake gasket, so good for painting, lifting, or storing a flathead
02-04-2020, 02:30 PM | #36 |
Wow. That is brilliant. I like the idea that you matched the intake profile. I'm leaning towards painting my block a different colour than that of the heads and intake, so that would be perfect for such a scenario. The adjustable lift is just icing on the cake. Someone should be selling this concept.
02-04-2020, 02:58 PM | #37 |
Unable to remove my post sorry.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
