Old 01-29-2020, 01:23 PM   #1
37 Coupe
37 Coupe's Avatar
Default spark plug connector pictures
I am never going to show this car so I should have bought the first years series of plug connectors instead of the offset ones for my '31. But since I have a '31 this is what I ordered and I don't know why or which orientation the offset goes,the early ones were a no brainer,straight. I know it does not matter if not shown I guess but if I am to install them I guess I would like to do them correctly. Must be some reason Ford changed to this.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 01-29-2020, 01:26 PM   #2
kenparker
kenparker's Avatar
Default Re: spark plug connector pictures
two to the left. two to the right. fore and aft of center. he-he. ken
kenparker is offline   Reply With Quote
Old 01-29-2020, 02:40 PM   #3
37 Coupe
37 Coupe's Avatar
Got it I think.Good thing I am a Navy vet.Thanks Ken.
Old 01-29-2020, 03:44 PM   #4
keyswitch1
I thought it was one on the left and three on the right ??
keyswitch1 is offline   Reply With Quote
Old 01-29-2020, 03:48 PM   #5
Ruth
I never thought about that. I'm so anal I'm going to have to go out and check now!
I heard Ford cut them that way to cut costs, less scrap.
Ruth is online now   Reply With Quote
Old 01-29-2020, 04:09 PM   #6
Synchro909
Synchro909's Avatar
37Coupe, I note you say you will never show this car. Mine are the same so I take measures to avoid the (in)famous Model A cross fire. I do one of two things: Either I extend the lead on #3 so that it sits further from the distributor body or I slit a piece of plastic tubing and slip it over #3 lead.
If the cross fire happens to you, it can take finding unless you are aware. I'd rather prevent it happening.
Accidents hurt. Safety doesn't.
Old 01-29-2020, 04:30 PM   #7
captndan
captndan's Avatar
The pictures are correct. 1234
captndan is offline   Reply With Quote
Old 01-29-2020, 04:32 PM   #8
Ruth
FYI, 'B' leads are longer so they are further away from the body when installed on the 'A' I put shrink tubing over mine "Just in case".
Old 01-29-2020, 04:56 PM   #9
37 Coupe
37 Coupe's Avatar
Which picture? I have different positions between them?
Old 01-29-2020, 05:48 PM   #10
37 Coupe
37 Coupe's Avatar
So the reason for the change in 1930 was to eliminate cross firing between the connectors?
Old 01-29-2020, 09:18 PM   #11
Synchro909
Synchro909's Avatar
If the later ones are longer, that may be the reason. When I lengthen them, I add about 10 mm (3/8")
Old 01-29-2020, 10:11 PM   #12
Jim Mason
Jim Mason's Avatar
The offest was to use less bronze. they interlink...
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 01-29-2020, 11:30 PM   #13
J Franklin
J Franklin's Avatar
I would wager they never had a thought about the direction of the offset at the factory especially close to shift change!
Old 01-30-2020, 10:06 AM   #14
JD 1931
JD 1931's Avatar
I would position them so they are farthest away from each other...
JD 1931 is offline   Reply With Quote
Old 01-30-2020, 11:14 AM   #15
Ruth
The "B" leads are longer because the distributor is a bit taller due to the advance mechanism inside.
