06-17-2016, 06:34 PM | #1 |
21 Stud Coolant Flush Tips & Tricks Needed
Hi Everyone, I've gotta do a cooling system flush. I'm looking for a clever way to force water upwards from the lower hose out the filler neck with the radiator in the car.
Car is a '35. Engine is a '37-ish block with earlier heads w/pumps in heads and blockoff plates. Radiator doesn't have drain cocks at the bottom. Sorta seems like a '35 small radiator but not certain. Pulled lower hoses to drain earlier this week. Hoses deteriorated from probably decades of oil dripping on them. I put them back on. New hoses coming. So I'm draining it again and looking for suggestions for flushing the radiator and if possible block. The debris seems like it may be from the hoses.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 06-17-2016 at 07:20 PM. |
06-18-2016, 05:01 AM | #2 |
Re: 21 Stud Coolant Flush Tips & Tricks Needed
Could you let it dry out a bit and get in there with a vacuum cleaner? You'd probably have to fashion some sort of small diameter extension pipe and keep bending it to shape. (Copper?)
A difficult one, that's for sure. |
06-18-2016, 06:30 AM | #3 |
this is a "zoo" flush gun, there is a water valve, and the little lever is the air,put in lower hose, turn on the water, when full of water hit the air, a block can take more pressure,and full pressure, but with radiator it is best to not "hit" it too hard, the air forces the water to nove fast and carry out debris
I know the tool is not common now, but easy to make something like it, just some adapters to adapt hose to the garden hose nozzel, and a fitting---drilled hole for blowgun ---first start with reverse flow, after debris stop reverse direction----then reverse direction again till nothing comes out anymore |
06-18-2016, 06:30 AM | #4 |
Disconnect the radiator from the engine block.
Fill the cooling system with vinegar, let it set. It is about Five bucks for 4 gallons at your local grocery store. Fill it up let it set for a few days I had to do mine four times. flush well after each treatment. I was amazing at all the crap that came out. |
06-18-2016, 06:31 AM | #5 |
wrong picture---this is flush gun
06-18-2016, 08:28 AM | #6 | |
The first thing I would suggest doing is getting all those pieces of black rubber?? out of the radiator, then start doing the flushing.
06-18-2016, 08:34 AM | #7 |
I filled the radiator and engine with vinegar and let it sit for 10 days, starting it from time to time. Drain it outside, it is a mess. Then I disconnected the lower hoses from the block and plumbed in 1 1/4 pvc pipe to the hoses. I used 2 ells and a tee with pipe to connect them so that the water goes in the tee and through the ells to the bottom of the radiator. I used a large water tank about 12' high so that I had a lot of water at low pressure but you could plumb the tee to a hose too. First I took the cap off and flushed the radiator then when it was clean I put the cap back on and back flushed the engine. I then reversed the lower pipes to the block and did it all again. I went back and forth until only clean water came out. It now runs cool maybe too cold sometimes in cool weather. Good luck.
The best way to have a friend is to be a friend. Howdy Doody |
06-18-2016, 08:49 AM | #8 | ||
36Bill, Any chance you still have that rig laying around? Can you snap a pic? I think I'm visualizing it, but you know, a picture tells a thousand words. My idea is I want water flowing upwards and eventually downwards through the radiator, then I'll move to the block cuz I'd be a fool to think that stuff is only in the rad! Thanks Kurt. That gives me some more ideas. Thanks everyone for the comments and suggestions!
06-18-2016, 09:42 AM | #9 |
Tangled,check eBay I see several used and new air assisted back flushers.I have used the vinegar treatment followed but a air assisted back flush to end my overheating problem on my 36. phil
06-18-2016, 09:54 AM | #10 |
Don't know if this would work for your 21 stud but it works great for my 59A Check it out and see: https://www.fordbarn.com/forum/showthread.php?t=83557
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
06-18-2016, 11:10 AM | #11 |
Here are some pics of what I used. The first 3 show the pipes in front of my PU as it would sit in use. I didn't glue any as I had a low pressure water flow. The last shows the tank and most of it's connection, one ell and some radiator hose are someplace else. This is a tank for filling our sprayer on the farm but you could make something out of a barrel on a stand with a 1 1/4 pipe to feed it. A hose might work too, never tried it
Bill
06-18-2016, 11:17 AM | #12 |
seeing all that crud in the top of teh radiator, i would recommend some extra work and remove the radiator and take it to a radiator shop and have the upper & lower tanks removed and then the core rodded out. just flushing wont remove much of that stuffg that took years to accumulate....
06-18-2016, 11:21 AM | #13 | |
06-18-2016, 02:12 PM | #14 |
Consider getting some bunjy cord around the right side of the bottom pulley then up to the left pump then the revers on the other side .this will run the pumps back wards .( not sure if that would work though because of the distributor) ,The vinegar idea I am all for soaking it min for 10 days .I have used a vacuum cleaner with a smaller tube taped to it ,worked OK .Ted
06-18-2016, 02:33 PM | #15 |
donald1950, I thought the same thing, the problem is finding a shop that does more than putting in a new radiator. I had found one shop that said they would boil it out but when it came back there was no difference. I then tried the vinegar and flush and it works, cheaper too.
Bill
06-18-2016, 05:17 PM | #16 |
If you can set up a back flush how ever. Maybe just cap of one lower spigot (frost plug in the rad hose?) Anyhow get water going in there from the bottom up and see what comes out. If that doesn't get it all, try a small brush with a twisted wire handle that you can bend, and gently massage along the top of the tubes. Most of that stuff will be in the top of the radiator. Do it while the water is coming up.
See how you go. The best result of course, would come from the top and tailing of the radiator. |
06-18-2016, 05:27 PM | #17 |
Hi Again. THANKS EVERYONE for their comments and suggestions.
36Bill, excellent. That was almost what I visualized but I can see what you did will be much better! Thanks a whole bunch for the help. Also thanks for the air assist suggestions, will explore, I think I have stuff on hand to do that. I'm not sure what will happen with this car. So I'm trying not to take it apart for now. I haven't said much about it but I took it from the garage it's been in for 53 years. Wasn't looking for another car but it found me. Am concentrating on getting it running reliably to the level that I can within that restriction.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 06-18-2016 at 05:34 PM. |
06-18-2016, 05:58 PM | #18 |
I took the bottom tank off my 33 rad and rodded the tubes out. Four pieces of 1/16" welding wire side by side should pass through the oval tubes.
Mart. |
06-18-2016, 06:38 PM | #19 |
Hi All. Thanks Mart. I have some great welder guys owing me some favors so if the radiator comes out I'm pretty sure they could deal with the soldering and you've given me the tip on the cleaner. The tanks are soldered on top and bottom, correct?
Not taking this one apart until fall if at all possible.
06-18-2016, 06:48 PM | #20 |
If it were mine I would take it to a radiator shop rather than trying to do it myself .Soldering the tank is tricky and they use a torch made for radiator repair. They also have a tank to check for leaks. Phil
