09-27-2010, 11:44 PM | #1 |
Charging problems
09-27-2010, 11:50 PM | #2 |
Re: Charging problems
Are you running 6 volt + ground?
Connect a volt meter to ground and the alternator output and take a reading with the engine off. Then start the engine and take a reading again. Then turn the lights on and take a third reading. Let us know what the three readings are. |
09-28-2010, 08:51 AM | #3 |
Three possible fixes: 1) Install & use a battery disconnect in the battery ground lead. 2) Use a correct 3 wire alternator hookup. 3) Drive the car more often! |
