06-26-2018, 08:36 AM | #21 | |
Re: Do ALL banjo rearends require a hub puller to remove the brake drum?
You've got a bunch of old geezers here with a hell of a lot of 'real world' experience when it comes to gettin' these drums off in one piece, UNDAMAGED, and fit to be re-used. This is one of the very few subjects (when it comes to old Fords) that has but ONE, definitive solution. That little thingie you see on eBay is a joke when it comes to a really-tight, properly-installed drum. Do yourself a huge favor....bite the bullet and get the real deal. DD winfield tool works 1-631-928-3316 p.o.box 476 port jefferson n.y. 11777 hub puller |
06-26-2018, 08:49 AM | #22 | |
What DD said times two! |
06-26-2018, 09:32 AM | #23 | |
http://www.vintageprecision.com/prod...ers/index.html
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 06-27-2018 at 05:11 AM. |
06-26-2018, 10:03 AM | #24 |
OK, thanks for the advice.
Matt 24:36-41 |
06-26-2018, 10:11 PM | #25 |
06-26-2018, 11:38 PM | #26 |
The one you posted looks like it'll work fine, if it clutches the slot in the drum and you keep the axle nut flush to the axle end. its all a proper krw tool does. some more... https://www.fordbarn.com/forum/showt...5686&showall=1 https://fordbarn.com/forum/showthrea...8518&showall=1 You wont ever never regret buying the right tool ever never. I also know you couldn't go wrong with mac vp's offer. super nice option. i'd seriously consider. You don't want to make this a 1k problem or more. Last edited by Tinker; 06-27-2018 at 12:38 AM. |
06-27-2018, 10:15 AM | #27 |
All this talk about pullers made me decide to go ahead and purchase the best, ( I’ve had cheap ones fail) hub puller available.
I was disheartened to call the Winfield tool works phone number I found in one of my older V8 times magazines, only to find that they had shut down and are no longer making these fine tools. |
06-27-2018, 10:34 AM | #28 |
After going through all the hell of removing the hubs, I bought the hubs and drums thst will come off seperately. Al
06-29-2018, 05:35 AM | #29 |
Go to Vintage Precision Inc in Benicia CA. Their puller kit is excellent. I purchased one for my '46 and was happy to have it. The P/N is VP-FHP1, and the price (well worth it) is $125.00. It comes in a nice plastic case.
06-29-2018, 07:15 PM | #30 | |
Woo hoo! Am I lucky. I just now got around to working on the back and low and behold, the drums come off separate from the hub. Talk about luck, I need to go buy a lottery ticket. Are these aftermarket or just a late change by the factory?
Matt 24:36-41 |
06-29-2018, 07:48 PM | #31 |
I think someone’s been in there before, studs are swadged to drum, unless they have been changed and not reswaged
06-29-2018, 08:56 PM | #32 |
Yes, someone has. the studs are flopping around. I will need to secure them to the hub before I put it all back together, can't have the studs falling back into the pit.
Matt 24:36-41 |
06-30-2018, 08:42 AM | #33 | |
That's because the PROPER-sized studs (correct diameter) for a press-fit are difficult (if not impossible) to find without resorting to reaming the five original holes in the hubs to a compatible size that will accommodate an available stud of the correct diameter AND length. DD |
06-30-2018, 09:42 AM | #34 |
Is this tool as good a quality as the Winfield tool?
06-30-2018, 10:46 AM | #35 |
10-25-2018, 02:50 PM | #36 |
10-25-2018, 04:24 PM | #37 |
Boling Bros- MT car makes hubs and detachable drums.
http://www.mtcarproducts.com/productsgrid.html John |
10-25-2018, 09:38 PM | #38 |
If you go with separate hub & drum assemblies, it does make servicing the brakes a lot easier, however, if/when you need to take the complete rear apart, you will still need a puller to remove the hub from the tapered axle, unless the axle nut has not been torqued to spec.
10-25-2018, 09:40 PM | #39 |
Think rear hubs is 180 lbs? If they are loose you will do damage. Anything torqued that much and is 40+ yrs old is going to be hard to remove.
Puller really makes it easy. . Last edited by Tinker; 10-25-2018 at 09:50 PM. |
10-28-2018, 11:22 AM | #40 |
Just a reminder, when putting the hub on the axle,make sure the rounded off end of the square key is down and towards the inboard direction. If installed wrong the hub will not run true. Al
