Old 09-13-2017, 08:49 PM   #1
fred93
fred93's Avatar
Default 29 Tudor rear window shade question
I am restoring a 29 Tudor Standard. There was no interior in the car when I started working on it. I have the old interior (don't have any idea if it is original or not) The rear window shade has small eyelets on each end of the old shade that is supposed to have a string running from the top area (around where the shade roll is attached to the body and it goes down from there).
Does anyone have any pix of where the string attaches top & bottom.
I found one pix of the attachment at the bottom but I don't know if it is correct-it looks like the string is held in place with a thumb tack-see attached pix
fred93 is offline   Reply With Quote
Old 09-13-2017, 08:54 PM   #2
700rpm
700rpm's Avatar
Default Re: 29 Tudor rear window shade question
The picture is correct. You have to find the wood frame back there, though, to put that tack into.
Ray Horton, Beaver Chapter, MAFCA, Portland, OR
Old 09-14-2017, 08:57 AM   #3
100IH
A thumb tack with a longer spike helps to hold it in place. Head is painted with the color on the garnish trim. Slightly lower or higher is a way to keep it in place, fresh wood. Keep the string parallel. The picture shows the tack too far down in my opinion. You don't want or need to over extend the shade roller, just to the edge of the metal frame.
100IH is offline   Reply With Quote
Old 09-14-2017, 11:14 PM   #4
fred93
fred93's Avatar
Where is the tack positioned at the top--any pix? Looks to me like it is directly behind the shade roll???
Old 09-14-2017, 11:27 PM   #5
duke36
Recollection is the guide string ties to the shade roller end brackets; perhaps someone has a photo. Some factory photos show the bottom tack just below the window frame bottom, not down so far as in the photo.
Old 09-14-2017, 11:32 PM   #6
Bill Cilker
Bill Cilker's Avatar
Fred
Here is a picture of the Shade string on my 1931 Vicky. the string has a knot on the end and goes through the hole in the shade bracket from the shade side. Then over the top of the shade bracket and down the inside to the the tack below the window. See pages 12-13 & 14 of the latest revision of the restoration guidelines.
Bill Cilker, Jr
Unrestored 190A
45B, 160B & 189A
Bill Cilker is offline   Reply With Quote
Old 09-15-2017, 11:11 AM   #7
fred93
fred93's Avatar
Originally Posted by Bill Cilker View Post
Fred
Thanks for the photo. I so hate it when I get into things that someone else has taken it apart.
I have the restoration guidelines book but it is are not the latest revision. Do I need to purchase a new book? And where do I get that?
And BTW what kind of string is used?? Is it available somewhere??
