Old 03-05-2020, 04:59 PM   #1
JT1930
JT1930's Avatar
Default Close spray paint color.
Does anybody know of a spray paint color off hand that is close to the chicle drab. Itís just going on my 30 coupe with a 32 firewall so it doesnít have to be exactly the same. If I canít find anything itís going a cream color as a last resort.
JT1930 is offline   Reply With Quote
Old 03-05-2020, 06:31 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Close spray paint color.
Maybe black would look good if you can't find a close color.
Old 03-05-2020, 06:42 PM   #3
Ted Duke
Go to a paint supply store. They can scan it and sell you a dab or a gallon.
Ted
Ted Duke is offline   Reply With Quote
Old 03-05-2020, 09:56 PM   #4
JT1930
JT1930's Avatar
Ted thatís a good idea. I may try a body shop supply place near by. I was told they match colors. Just donít want to spend a fortune for a little paint.
Old 03-06-2020, 02:15 PM   #5
77Birdman
My local NAPA will scan and mix paint as well. They will even put it in a spray bomb if you want.
77Birdman is offline   Reply With Quote
Old 03-06-2020, 04:55 PM   #6
marty in Ohio
marty in Ohio's Avatar
The local auto paint store near me would match your color and put it in a rattle can for about $25.00 a can. This was a couple years ago.
Marty
marty in Ohio is offline   Reply With Quote
Old 03-06-2020, 05:03 PM   #7
walls
https://www.66autocolor.com/Auto-Spr...t.htm?CartID=1
I’ve used this place with pretty good success.
If you only need a can or two, otherwise it’s pretty expensive.
walls is offline   Reply With Quote
Thread Tools
Display Modes
