02-08-2020, 08:46 PM | #1 |
1937 fan belt short
I have a stock 37 sedan with a 85hp flathead. Fan belt is short. P.N. 78-8620-A. Is this the correct part. Got it from Drake. Catalog said it was for a 37 passenger. Thanks Bruce
02-08-2020, 10:54 PM | #2 |
Re: 1937 fan belt short
Make sure you have a 37 intake manifold, 37 generator and 37 pulley. I am the LAST person to say a remake part is correct, but if over the years, the intake or generator was rebuilt with a larger pulley or whatever it could cause this sort of issue. That part number looks correct to me.
02-08-2020, 11:24 PM | #3 |
02-09-2020, 08:04 AM | #4 |
Try a B54 . worked for me ! kx
02-09-2020, 08:21 AM | #5 |
Anyone have a pic of an original intake to compare with?
02-09-2020, 08:34 AM | #6 |
02-09-2020, 09:16 AM | #7 |
Depends on what pulley is on the generator to...From smallest to largest around is 2 sizes of belts different !
02-09-2020, 09:39 AM | #8 |
Just measure it and get one 1" longer. A b54 would measure about 57".
02-09-2020, 11:33 AM | #9 |
trying to post pics????????
02-09-2020, 11:53 AM | #10 |
If you still can't get the photos to post, email them to me and I can post them for you: [email protected]
02-09-2020, 11:36 AM | #11 |
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
02-09-2020, 01:22 PM | #12 | |
If you locate a NOS belt of that same number, you can easily see the Drake belt is shorter. If you have the correct intake and generator pulley (3 11/16" diameter), you will be unable to get his belt to fit regardless of what you may try. If you have a later pulley (3 3/16" diameter, introduced late 1940 ) you may be able to tip the generator forward, slip the belt on and get the generator back in place. It's close, but can and has been done.
02-09-2020, 11:14 PM | #13 | |
I've had the same issue with my truck. I run one too long now. Car one is way too short. I don't like the generator up so far but it works. Maybe I'll look at the car version. |
02-09-2020, 11:05 PM | #14 |
Here are some photos Bruce wanted posted.
