11-10-2021, 02:32 PM | #1 |
59A cam. Undersize journals?
Has anyone ever encountered a cam with undersize journals? I have one here that appears to be .010" down on the others I have. Were bearings ever available to suit?
Thanks in advance. Mart. |
11-10-2021, 02:35 PM | #2 |
Re: 59A cam. Undersize journals?
Yes, I don't know how common though, I found a set at Hershey
11-10-2021, 02:47 PM | #3 |
The .010 undersize cam bearings are still being made and easy to get. Fords minimum dimension for the cam bearing journals is1.7955. When I come across a cam that I want a new profile ground onto if the cam measures under that 1.7955 dimension the journals are now ground the .010 undersize so it can be used once again. I have a few 1932 steel cams with different profiles most of them have been ground undersize probably due to the fact the original 1932 Ford V-8 block did not have cam bearings the cam rotated in the iron of the block.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
11-10-2021, 02:54 PM | #4 |
As Ronnie said pretty common. I have also see cams removed from original engines with.010 under. I also keep under sized bearings & often have cams ground.010 under
11-10-2021, 04:20 PM | #5 |
