Old 08-23-2021, 05:29 AM   #21
roddyb34
roddyb34's Avatar
Default Re: Volvo Laycock Overdrive DIY
With a bit of looking around I found myself an M46 trans and laycock overdrive,,,not that it helps but it’s an aluminium main case ,,it’s out of a 740 Volvo,,,
File Type: jpg 5E5F93C0-3A9A-43ED-AA9A-5799BAA27E49.jpg (60.6 KB, 50 views)
roddyb34 is offline   Reply With Quote
Old 09-12-2021, 08:07 PM   #22
Mike/Nebraska
Not quite the same topic but....I bought a volvo o.d. mounted in the torque tube from a guy in Cali. who told me he bought it from Rich Little. I called and sent pictures of the unit to A guy in Rich Little's shop and he said it wasn't one of theirs. He did send me a wiring diagram for it though. Nowthe question. I've seen people on here saying they use the unit on 6v. I wired it up and nothing. When I put a battery charger on 12v. to the solenoid I could hear it click. So would a 12v mower battery under the seat with the o.d. wired to it solve my problem?
Mike/Nebraska is offline   Reply With Quote
Old 09-13-2021, 03:08 AM   #23
Boston Bruce
Boston Bruce's Avatar
My Laycock overdrives all function fine on 6 volts. Are you saying that you hooked a 6V battery charger up and tried it that way?
Boston Bruce is offline   Reply With Quote
Old 09-13-2021, 09:52 PM   #24
Mike/Nebraska
No, I couldn't get it to work off of my 6v battery in the car. So I put a battery charger on 12v to the solenoid and it clicked in.
Old 09-13-2021, 10:47 PM   #25
NZ28ModelA
NZ28ModelA's Avatar
Hi Mike,
I think you might have other issues.. My OD also works fine with 6V, which i believe they all should do.. I think you will be over engineering the repair by trying to wire in a 12v battery when you shouldn't have to..
Maybe either check your wiring to the solenoid, or maybe the condition of the solenoid itself?
Steve
NZ28ModelA is offline   Reply With Quote
