06-21-2021, 05:33 PM | #21 |
Re: New Carb
Here are the horsepower and torque curves for the Weber on an otherwise stock engine. A high compression head will also help.
https://www.modelaparts.net/dynosheets.htm/web3236.htm Here is a touring engine with the Weber and a higher compression head. https://www.modelaparts.net/dynoshee...pintoweber.htm Throw in a cam and some bigger valves and it goes up. Best to have a stronger lower end with anything over 60 hp.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 06-21-2021 at 05:39 PM. |
06-21-2021, 05:35 PM | #22 |
Re: New Carb
Tilly seems to have less problems.
06-21-2021, 06:18 PM | #23 |
Re: New Carb
Have had both. Prefer the Zenith. Car runs great, not leaks, looks right.
Enjoy. |
06-22-2021, 05:38 PM | #24 |
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Re: New Carb
Down draft Weber works good me.
11-28-2021, 03:59 PM | #25 |
Re: New Carb
Does anyone know if JR Bullock is still in business? His website no longer is there.
Took my Zenith off to try and locate a leak that has been an ongoing problem since I bought my 29 Fordor. Turns out the lower body is cracked at the secondary well and the previous owner/restorer tried to spot weld and paint it. So now I'm looking to replace my carb. |
11-28-2021, 04:10 PM | #26 | |
Re: New Carb
11-28-2021, 05:41 PM | #27 |
Re: New Carb
I'm so sorry to hear that. Thanks for the update. Sad news.
11-29-2021, 08:48 PM | #28 |
Re: New Carb
Tilly here...but hey, that's me
