Old 05-17-2019, 06:00 AM   #1
mike dixon
Default need piston
hello everyone
I did a stupid thing, im 67 and ought to know better, i dropped a small screw into my spark plug hole in my 1948 flathead pick up engine. then i started it, big mistake. I need a piston, some rings and a valve.
It has an H stamped onto the head, can anyone help me. thank you it is a 6 cyl
mike dixon is offline   Reply With Quote
Old 05-17-2019, 06:07 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: need piston
6 cylinder H engine ?
You need to check for what oversize you have if not STD to...
Old 05-17-2019, 06:09 AM   #3
JSeery
JSeery's Avatar
Are you sure there is not cylinder wall damage? If you are going to replace a piston, at a minimum the clyinder would need to be honed I would think.
Old 05-17-2019, 07:15 AM   #4
KiWinUS
KiWinUS's Avatar
I have some used H parts if it’s a 6 cylinder
Old 05-17-2019, 07:47 AM   #5
RalphM
RalphM's Avatar
I also have some NOS six cyl pistons and rings if you can determine the size you need.
RalphM is offline   Reply With Quote
Old 05-21-2019, 05:51 AM   #6
mike dixon
it is a 6 cyl, no wall damage i need a piston 618-401 5977 thank you can you call me please
Old 05-21-2019, 05:51 AM   #7
mike dixon
6 cyl i need a piston, can you call me 618-401-5977 thank you so much
Old 05-22-2019, 06:36 AM   #8
mike dixon
the piston is .040 still need it and rings and a valve
Old 05-22-2019, 06:39 AM   #9
mike dixon
.040
Old 05-22-2019, 07:03 PM   #10
RalphM
RalphM's Avatar
Let me look in my parts stash.
Old 05-22-2019, 08:01 PM   #11
RalphM
RalphM's Avatar
Pm sent
