03-17-2022, 12:35 PM | #41 |
Re: No spark at the plugs
Glad to hear you got it taken care of!
03-23-2022, 09:53 AM | #42 |
Unfortunately it only ran for a few minutes. Since than I’ve reset the timing changed the cap rotor and body, spark plugs and head gasket, changed the fuel and I am still having the same problem it won’t pop I have spark at the plugs and fuel in the cylinders still nothing? It’s driving me crazy. Fortunately it’s a short drive
03-23-2022, 10:33 AM | #43 |
Is your rotor in the position that Rob shows in post #39 when #1 is a TDC?
03-23-2022, 10:46 AM | #44 |
Daba, Every engine runs on first principles. Did you do the check that I recommended in post 38? The position of the rotor and the timing are all to make sure that the plugs fire at the right time. There can be a number of things out of adjustment that may look right but not provide the correct timing according to the first principles.
Look in the cylinders or use a wooden stick to sense when the pistons are at TDC.
03-23-2022, 10:50 AM | #45 |
I just tried to add oil in the cylinders again 2 capfuls cranked it over, have good suction and blow back start and stop for about one minute without putting stress on the starter reinserted the plugs and have the same problems no pop? I torced the head gasket down to 55 pounds and three successions
03-23-2022, 10:59 AM | #46 |
03-26-2022, 03:39 PM | #47 |
Change the wire from the battery to the starter. Make sure that you are using a heavy gauge wire, not a thin one for a 12 volt (modern) system.
