05-04-2019, 08:23 PM | #1 |
40 Front Stabilizer Bushings
Has anyone re-bushed the front stabilizer end bushings where it attaches to the 3033-C/3032-C bolts on a '40? The rubber (3558-A) is easy to find but mine are loose at the end bolts where they attach to the outer spindles. It looks like a shackle bushing but a different size.
05-04-2019, 09:35 PM | #2 |
Re: 40 Front Stabilizer Bushings
On my 2 40 passenger cars, they are ALMOST the same as the front spring shackle pin. The only difference I can see is that the stabilizer does not use a cotter pin so there is no hole for one and so nut is not a castle nut and it uses a washer.
05-04-2019, 09:42 PM | #3 |
Have you ever changed one? On mine, they look smaller and shorter than the front spring shackle bushings.
05-05-2019, 08:54 AM | #4 |
No, I haven't needed to. I believe the lack of cotter pin hole would give them a different part number. I haven't actually looked that part up but I will.
I need to do more investigating, my 40 Chassis book only shows the early stabilizer bar which is completely different. Green Bible does not show a 40 front axle. The more I think about it, I have several NOS perch bolts that already have that part installed. If you are interested in changing the perch bolts out (often not a simple task) PM me as I don't anticipate needing my extras. Last edited by deuce_roadster; 05-05-2019 at 09:12 AM. |
05-05-2019, 10:33 AM | #5 |
Here's some photos that may help. The Chassis Parts Book has the pictorials.
05-05-2019, 10:40 AM | #6 |
05-05-2019, 01:22 PM | #7 | |
I for one, have stopped offering advice to Philip as I simply have done no research in to such a super rare vehicle.
05-05-2019, 01:30 PM | #8 | |
"Numerous other posts" probably means two. I found the Deluxe wagon used Standard interior door handles as well as the dash being painted as a Standard color to match the rest of the interior. |
05-05-2019, 01:32 PM | #9 |
That's good to know. Thanks for that. Since I have some extra bushings, I'll give it a go. Phil
05-05-2019, 06:04 PM | #10 | |
I know I really like the "odd" one and would thoroughly enjoy you sharing any documentation uncovered that explain the anomalies of your car. I'd be certain to include any and all in my forthcoming book.
05-05-2019, 06:20 PM | #11 | |
