05-02-2012, 09:22 PM | #21 |
Re: Timing
I have timed my A without much problem. I was a little suprised how hard it was to turn engine over with even the plugs out. I could not turn just the crankshaft pulley. I had to use the fan. Is this normal. Joe B.
05-02-2012, 11:04 PM | #22 | |
Re: Timing
Chief always said, "The easiest way is the best way if it does the job properly!" Since your engine turns a little hard, maybe that's a good sign that it's not a "loosey-goosey" old WORN out chunk of iron! Bill W.
05-03-2012, 06:56 AM | #23 |
Re: Timing
A couple of common reasons why some may have trouble hand cranking the engine could be misalignment of the engine transmission assembly with the frame or worn crank nut or crank handle.
05-03-2012, 10:07 AM | #24 |
Re: Timing
Thanks for all the good info from everyone. We are going to try to time it on Sunday and I'll let everyone know how it goes.
05-03-2012, 08:19 PM | #25 |
Re: Timing
The crank is a little hard to turn normally but if you do it a little at a time (slowly) the compression with ease and you should be able to do it without a problem.
05-03-2012, 11:05 PM | #26 |
Re: Timing
Rust and roll will never die |
05-04-2012, 09:28 AM | #27 |
Re: Timing
05-04-2012, 10:34 AM | #28 |
Re: Timing
I agree that the problem is more than likely a running lean condition. The air fuel adj. screw on top of the carb, only controls the idle circuit. If the idle speed adjust screw isn't set for a low idle speed, the idle circuit won't kick in and the air adjust screw will have NO effect on idle.
Vacume leaks cause a lean condition. The engine depends on vacume to draw the fuel air mix, up the manifold to the combustion chambers.If there is a vacume leak the engine will be drawing more air which leans the mix. sometimes opening the GAV will help compensate by richening the mixture. If the vacume leak is severe enough, nothing short of fixing the leak will help at all. If a pot metal carb is used, the first place that I would look is where the carb meets the intake manifold. The second would be the manifolds and condition of the seal between the manifolds and block. A lot of cars have warped and cracked manifolds caused from running with retarded timing or driving with the spark lever half way up the quadrant. Torqueing and over tightening the manifolds is also a major cause of warped and cracked manifolds . WD 40 is NOT good to use when checking for vacume leaks. The formulation of WD 40 has been changed and it is no longer flamable. The test fluid or gas needs to be flamable to show an increas in engine speed when testing. Starting fluid or carburetor cleaner sprayed in the suspected leak areas is the best vacume leak test product. |
05-04-2012, 12:23 PM | #29 | |
Re: Timing
05-04-2012, 12:27 PM | #30 |
Re: Timing
Recheck your carb. mounting. A mounting bolt that is too long can interfer with the carb. housing and not allow the carb. to tighten against the manifold. Also make sure you don't have a vacuum leak at the fitting where the line went for the vacuum wipers. Manifold bolts that are loose can also cause the engine to run lean.
05-04-2012, 01:12 PM | #31 | |
Re: Timing
Turn the key on and push the starter rod with your hand while you hold the coil wire 3/8" from a head nut to check for a hot blue spark. Use a compression tester to check for good compression and within 10% on all cylinders. |
05-04-2012, 01:22 PM | #32 | |
Re: Timing
On the other hand, if no vacume leak can be found, I would check points gap before messing with the timing. If the points gap has closed it will cause similar problems. I set my points at .022 but anywhere from .018 to .022 will work. Its best not to mess with the timing until other avenues are explored. There is a lot of confusion about timing procedure. When checking the timing, watch the rotor tip. When the timing pin drops in place, the trailing edge of the rotor tip should line up with the number one plug wire contact in the distributor cap body with NO clockwise backlash. Counter clockwise backlash will probably be present but will have no effect on timing. If you can follow what I am saying, it should solve your problems one way or the other. Just one other thing. If you are having to use ethanol adultrated gas and it has been in the tank for a few weeks, this may be the problem. Good luck and keep us posted. |
05-04-2012, 02:07 PM | #33 | |
Re: Timing
When I was involved in the MG Midget world there were a few serious under bonnet/hood fires caused by people using carb cleaner to find air leaks. Naturally any flammable substance will ignite when sprayed near a very hot manifold. It is my understanding is that WD40 or some other non volatile aerosol proves the air leak, by blocking the leak temporarily before it evaporates away. The theory is that the rpm rises, due to the mixture becoming richer while the air leak is blocked. Roly |
05-04-2012, 02:28 PM | #34 |
Re: Timing
Blessyouboys, with the plugs out, turning the fan doesn't do any damage to the fan, or any thing else.
05-04-2012, 03:06 PM | #35 |
Re: Timing
[QUOTE=mothy;419459]Thinking of sfaety, I have to put another angle to this statement.
When I was involved in the MG Midget world there were a few serious under bonnet/hood fires caused by people using carb cleaner to find air leaks. Naturally any flammable substance will ignite when sprayed near a very hot manifold. It is my understanding is that WD40 or some other non volatile aerosol proves the air leak, by blocking the leak temporarily before it evaporates away. The theory is that the rpm rises, due to the mixture becoming richer while the air leak is blocked. Roly[/QUOT I agree that carburetor cleaner and starting fluid are flamable. I wouldn't test for vacume leaks if the manifold is red hot . Common sense is needed, whatever!! The purpose of the flamable liquid is, when the vacume leak draws it into the combustion chamber, engine speed will increase and show where the leak is. WD 40 just won't work in this case period. WD 40 will not temporarily block the leak, it will just be drawn in to the cumbustion chamber just like air and will make NO difference in engine speed. Last edited by Purdy Swoft; 05-04-2012 at 03:29 PM. |
05-04-2012, 03:12 PM | #36 |
Re: Timing
Stethascope with open hose is GOOD! Yes, I repeat a lot!
Repetition is the MOTHER of learning & the FATHER of boredom! Bill W.
05-05-2012, 09:40 AM | #37 |
Re: Timing
05-05-2012, 09:44 PM | #38 | |
Re: Timing
Like, was our pinkie designed to clean our nose boogers? It's called IMPROVISING! Show me one real mechanic out there who has NEVER turned an engine by it's fan, get real! Bill W.
05-05-2012, 09:54 PM | #39 |
Re: Timing
Hey Bill, hes right it was not designed to turn over the engine,BUT it works so why not use it?, i use that method to turn the engine for some settings, like setting points and static setting the timing, my theory is if it works, use it, How is your wife? comforable at the least i hope,
05-06-2012, 12:54 AM | #40 |
Re: Timing
I coud make a living, just traveling around the country, settin' folks timing & pin pointing vacuum leaks! Bill W.
