Old 09-22-2019, 08:32 PM   #1
ericr
ericr's Avatar
Default Improved Steering Column Support
does anyone know why there is not the improved steering column bracket for the 28-29 models? does the structure of the earlier models not accommodate such a bracket?
ericr is offline   Reply With Quote
Old 09-22-2019, 08:45 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Improved Steering Column Support
Prolly cos they were not used by Ford in the early cars. I make such a bracket for '28-9 RHD cars which can be adapted to the later ones.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 09-22-2019, 09:09 PM   #3
Bill G
Bill G's Avatar
My 29 included one when I bought the car. From the stuff I read, its only a matter of drilling one hole to modify the 30-31 support to fit the bolt pattern of the 28-29 dash rail. The reason mine needed the support was pretty apparent, so if you have a 28-29 without the support, I would recommend getting the support.
Bill G is offline   Reply With Quote
Old 09-22-2019, 11:46 PM   #4
Russ/40
Russ/40's Avatar
If you make the installation with an adapter piece of 3/16 ths plate you can do it without drilling any holes in the body.
Russ/40 is offline   Reply With Quote
Old 09-23-2019, 12:12 PM   #5
1931 flamingo
1931 flamingo's Avatar
ericr: Above on the BLACK band is a Search function. This has been covered many times brfore even with pics for your application if I remember correctly.
Paul in CT
Old 09-23-2019, 03:43 PM   #6
ericr
ericr's Avatar
Paul in CT
I am sure you are correct but every single time I try the "search" function on this site, I come up with literally dozens of pages of scores of hits, the vast number of which are apparently unrelated, even when I put the searched item in parentheses.
This subject does come up consistently but usually within the context of leaks around the original bracket on the gas tank.
Old 10-30-2019, 06:50 PM   #7
GPepper
Hi, Greg from Texas
i have a 1929 Pheaton RHD
I'm looking for a Steering support for my restoration.
Like all the early cars it has a stress crack on the gas tank steering support bracket.
Please let me know what you have and how we cna communicate about me buying one from you.
Greg
GPepper is offline   Reply With Quote
Old 10-30-2019, 06:51 PM   #8
GPepper
Originally Posted by GPepper View Post
Hi, Greg from Texas
Greg
Syncor99
Old 10-30-2019, 09:28 PM   #9
PalAl
PalAl's Avatar
This might be helpful.......... does not work for a 29 Briggs body!
PalAl is offline   Reply With Quote
Old 10-30-2019, 09:33 PM   #10
PalAl
PalAl's Avatar
This may be even more helpful..... still won't work on a Briggs 29!
Old 10-31-2019, 04:18 AM   #11
quickchange
quickchange's Avatar
GPepper have mailed you, we produce the RHD version here in NZ , Will be your way for Pate swap next year & bring with me or we can ship, Need any other RHD parts ? may be able to help. Also produce the new short RHD steering box drop arm for lighter steering,
quickchange is offline   Reply With Quote
Old 10-31-2019, 10:33 AM   #12
katy
katy's Avatar
After you click on the "Search" tab, you need to click on the "advanced search" tab, then you can select which forum(s) to search in, otherwise you're searching in all the forums.
Old 10-31-2019, 10:37 AM   #13
30 Closed Cab PU
You can also try searching from a browser (Google), instead of using the Barn Search feature.. A lot of times doing it this way is a little more exacting. When you get teh results look for Ford Barn results.
30 Closed Cab PU is offline   Reply With Quote
Old 10-31-2019, 10:41 AM   #14
barkleydave
barkleydave's Avatar
I used the 31 bracket on my 29 ccpu easy install one additional hole no problem much stronger and no strain on tank.
barkleydave is offline   Reply With Quote
Old 10-31-2019, 10:44 AM   #15
Purdy Swoft
Purdy Swoft's Avatar
I installed a late thirty one steering bracket in my april thirty AA truck and didn't have to drill a hole .
Ford used the twenty eight-nine style cab until june thirty .
