10-20-2014, 12:29 PM | #1 |
Remember to Grease that little zirk on the rear Cam Actuating lever
Was having some real serious breaking problems. Took everything apart including all the rods..Then i found it..turns out actuating arm for the cam on the rear breaks was FROZEN Solid...after removing the backing plates and having to remove the arm I saw it was rusted solid to the bearing..In my haste over a long period of time that little zirk which became dirty and hidden I failed to grease and it froze up.. all fixed now and just as a reminder to everyone...dont forget that little puppy!!
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
10-20-2014, 06:01 PM | #2 |
Re: Remember to Grease that little zirk on the rear Cam Actuating lever
Mark: Changing your Avitar is messing me up .
Paul |
10-20-2014, 07:29 PM | #3 |
When I got my Tudor, those rear zerks still had blue tape over them from when the rear end was painted by previous restorer over 40 years ago. I greased them, the brakes work excellent.
10-20-2014, 07:37 PM | #4 |
I've been wondering what a Zerk is but this post has helped (I think) in a way not intended. It's a grease nipple!!!!!!
I haven't spent sleepless nights wondering about it but it now begs the question "Where did that name come from?" Anyone? |
10-20-2014, 07:52 PM | #5 |
Oscar U Zerk invented the grease fitting
10-20-2014, 07:57 PM | #6 |
And yea msmaron - your avitar changing threw me for a loop too Has anyone made a checklist people could print off about all the different grease zerks on a model A? Maybe have a space for when the oil was last changed also on it! I know theres the lubrication chart that shows how often and where to grease...
10-20-2014, 07:57 PM | #7 |
Thanks Big Hammer.
10-20-2014, 11:26 PM | #8 |
Of note here, Ford did NOT originally use Zerk fittings on the A. In many cases the original fittings have been replaced with Zerk style fittings. Later design Zerk guns (rights assigned to Alemite) not only accommodated off-axis engagement, but they also locked on the fitting. This later improvement permitted lubing without applying physical pressure to the fitting or use of a bayonet coupling. At that point lever pump guns with grease hoses came into use and the non-locking fittings on the "A" fell into disuse.
Anyone with a name like Oh, You Zerk! begs attestation, so here it is: (Note that these early gun fittings do not also hydraulically lock like later designs) |
10-21-2014, 04:46 AM | #9 | |
My Son, Gregg, (RIP) always was confused about FEMALE/MALE fittings, until Chief, his Grandpa, made a 3 finger gesture to him, & he NEVER was confused again!! Like ----->0 Bill W.
10-21-2014, 05:01 AM | #10 |
A rethreaded zerk & grease gun is a blessing when trying to disassemble stuck disc brake or drum brake wheel cylinders. I put a pressure gauge on a grease gun & it EASILY pegged out the 2,000 Lb. gauge!
On my friend's '47 Ford, someone didn't align 1 of the grease holes in 1 of his king pin bushings. We drilled through the bushing & slightly into the king pin, blew it out & put the zerk back in. With a grease gun & QUITE a bit of effort, we forced grease out of BOTH ends of the bushing, VOILLE' I'm glad they called it a ZERK, that's easier to say/write, than, "A SELF LOCKING FITTING FOR INJECTING GREASE INTO MOVING PARTS"! ZERK has a nice ring to it, kinda' like, JERK! Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 10-21-2014 at 05:10 AM. |
10-21-2014, 07:12 AM | #11 |
Mechanics started calling customers jerks for not greasing the fittings,eventually they became known as zerk fittings,get it?
10-21-2014, 09:13 AM | #12 | |
10-21-2014, 09:28 AM | #13 |
10-21-2014, 11:31 AM | #14 |
Bottom line..>Grease it ALL THE TIME.....
10-21-2014, 04:15 PM | #15 |
Remember those old "ZERKS" that looked like a light bulb base? They worked pretty good.
Wonder if anyone collects old grease cups? Saw an OLD airplane motor at the Smithsonian, with exposed timing gears & a grease cup on the front cam bearing. They must have brushed the timing gears with grease before flying. Same engine had NO valve cover & had squirt can holes to oil the rockers!! For sure, they DIDN'T need valve stem seals!! The carb. looked like it was machined out of a square block of BRASS! Bill W.
10-21-2014, 05:29 PM | #16 |
Big deal, so he invented pressurized grease coupling. What about finding the solution to the separation of grease whilst in a grease gun? Grrrrr!
10-21-2014, 10:38 PM | #17 | |
Bill W.
10-22-2014, 06:05 AM | #18 | |
Thanks to http://www.fordgarage.com/ for providing such a nice chart.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
10-22-2014, 09:49 AM | #19 |
Can you purchase this chart? The website does not allow printing
10-22-2014, 10:35 AM | #20 | |
http://www.macsautoparts.com/ford_mo...t-17-x-22.html There are also similar versions available for the Model T and the early V8s. |
