Old 04-09-2020, 05:23 PM   #1
Woody45
Question V8-60 L47 cam
I've been searching for a cam for my V8 60 and located one that is marked L 47. Is this possibly a Literio cam? Anyone have any specs for this? Any insight would be greatly appreciated.
Woody45 is offline   Reply With Quote
Old 04-09-2020, 05:29 PM   #2
Pete
Pete's Avatar
Default Re: V8-60 L47 cam
I have no info on that cam but am curious on what you are building.
You can email me if you want.
Old 04-09-2020, 07:56 PM   #3
Woody45
Hi Pete. Nothing exotic, I have a 29 A with a 60. It was built as a hot rod back in early forties. Runs like silk, but getting pretty tired. In process of assembling another 60 as a replacement. I'm looking for good street cam/touring cam.
Old 04-09-2020, 08:57 PM   #4
raybee
I would stick with a stock cam. You need torque, not high RPM horsepower. Ray
raybee is offline   Reply With Quote
Old 04-10-2020, 10:36 AM   #5
deuce_roadster
deuce_roadster's Avatar
Any of you Oregon guys remember a 32 with a V8 60? Somewhere along the way I ended up with a V8-60 transmission with a 32 rear mount on it. Was told it came from Oregon. Still have the trans if someone wanted to stop by I would give it to them (minus the mount). It is not the same as a regular V8 trans.
Old 04-10-2020, 12:51 PM   #6
flatjack9
flatjack9's Avatar
Absolutely true about wanting to retain as much low end torque as possible.
Old 04-10-2020, 09:32 PM   #7
40 Deluxe
Plus the 4.44 gears in the rear!
Old 04-11-2020, 07:32 AM   #8
Woody45
Yep, I have 4.44 gears with Columbia 2 speed.
