01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
front end alignment specs for a 1955 F100
Can someone provide me with the front end alignment sepcifications for a 1955 F100? <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
Re: front end alignment specs for a 1955 F100
caster 3 degrees min...4 degrees max, max variation between wheels 1/2 degree.....camber 1/4 degree min 1 degree max, max variation between wheels 1/4 degree....toe in, in inches 0 to 1/16 max....king pin inclination 4 degrees + or - 1/2 degree, the specs are the same for the 250 also <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #3 |
Guest
Posts: n/a
1954 and 56 use same specs <table><tr><td><font face="arial"> |
