Old 10-16-2018, 06:32 PM   #1
1932chevy
Default Houdaille Shock
Picked up a set of houdaille shocks for 6$ a piece and am in the process of freeing them up. I am using MAPP gas to heat up the threads.
Is there a better tool to use to open grab on to the body than channel locks. Should i use a strap wrench?I got this far and gave up until i can order a deep impact socket. I believe a 40mm deep socket will fit the nut the best.
are all the thread right hand?
1932chevy is offline   Reply With Quote
Old 10-16-2018, 07:07 PM   #2
160B
160B's Avatar
Default Re: Houdaille Shock
There are CW and CCW shocks and you do not want to mix parts. Disassemble each shock individually and keep all the parts for each shock in its own container so when you reassemble you keep the correct parts with the correct body.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 10-16-2018, 11:42 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
See reply #6.
https://www.fordbarn.com/forum/showt...de+tools+shock
Old 10-17-2018, 05:42 AM   #4
updraught
updraught's Avatar
"The emphasis on production probably explains why the endemic leaks were never fixed, why steel-on-steel rotor bushings continued to be used, and why shocks were shipped with glycerin after hydraulic oils became available"
http://www.goldcoastmodela.com/Shocks/hhist.html
Good luck.
updraught is offline   Reply With Quote
Old 10-17-2018, 03:36 PM   #5
flatford39
You are going to need a lot more leverage than a pair of channel locks. I use a 36" pipe wrench with a persuader extension and a lot of heat. some guys bury them in the charcoal of a weber grill to get them red hot.
It takes a lot of leverage to break them.
flatford39 is offline   Reply With Quote
Old 10-17-2018, 07:21 PM   #6
1932chevy
Originally Posted by Tom Wesenberg View Post
Thanks for sharing Tom. Did you make the internal hex using a rotary table and mill? What material did you make it from.
File Type: jpeg 773568C3-85A4-4B08-BACA-B334095C4759.jpeg (63.0 KB, 27 views)
Old 10-17-2018, 08:08 PM   #7
jw hash
jw hash's Avatar
1932, without seeing the bottom of that shock. it appears to be a 32 shock. if so they do not work very well on a Model A they are to tall and hit the brake rods.
the Diablo A`s put out a DVD on how to rebuild Model A Shocks. and I will say it is pretty darn good.
jw hash is offline   Reply With Quote
Old 10-17-2018, 11:31 PM   #8
1932chevy
Here is a photo of the backs. The first shock in this photo doesn’t indicate manufacturer and has no lock ring. Were there multiple manufacturers or maybe this one is a reproduction shock .
File Type: jpg 1FCC58CF-C099-4EFE-A302-28C6B19B7B2B.jpg (35.1 KB, 50 views)
Old 10-17-2018, 11:48 PM   #9
Tom Wesenberg
I wish I had a mill, but I had to use a drill bit to rough out a hex, then used a milling bit in my drill press and slowly and carefully milled out the hex. I then put the drill press head at a slight angle to put the taper to the hex. After that hex fit the shock hex perfectly, I then welded the two long handles to the large round center part.
Old 10-18-2018, 01:54 AM   #10
jw hash
jw hash's Avatar
the first three of them are 1932`s the forth one is a Model A
