04-04-2013, 03:12 PM | #1 |
Brakes again - 31 roadster
HEY GUYS ONCE AGAIN I HAVE A BRAKE QUESTION ; rear drums are removed, left rear has shoes but no em. shoes installed and the drum goes back on with no problem. r rear , all brakes are installed , em . brake is on , I cannot get the drum to go back on, it goes on up to the first thread of the axle very tight. this drum needed to be pulled off with a puller. Any suggestions, is there a way to adjust the em. shoes so as to install the drum? ? . FIRST TIME WORKING ON MODEL A BRAKES . thanks again THE HOOCH
04-04-2013, 03:23 PM | #2 |
Re: Brakes again - 31 roadster
Make sure your adjusters are all the way out, and you may have to sand the e-brake lining down a bit as the repop stuff can be too thick. Chamfer the shoe edges as well.
Good luck! |
04-04-2013, 04:51 PM | #3 |
