Old 08-31-2019, 05:39 PM   #1
jacob smith
jacob smith's Avatar
Default Flathead repair
Can anyone point me in the right direction to a repair shop in north eastern PA that is really good with Flathead fords.. I can not find the issue with my 36. Runs great for about 1/2 an hour. Then is starts missing a losing power. I have replaced or repaired.
carb
Coil
Distributor
Fuel pump
Fuel filters
Condenser
Fuel lines
Plugs
Wires
I just can not find the issue.
Ford
jacob smith is offline   Reply With Quote
Old 08-31-2019, 05:54 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Flathead repair
Have you checked for a blown head gasket?
Old 08-31-2019, 06:16 PM   #3
jacob smith
That I have not check but I have never seen oil in the radiator or water in the oil. Funny thing is if I turn the car off for 5 minutes and start it up it will run fine again but a couple of minutes later it will start acting up again. It also is not getting hot when it does this. The temp is right around 185. What ever the issue is seems to be something not related to heat because it is up to operating temp and runs fine. Seems to be something is giving out with time.
Ford
Old 08-31-2019, 06:19 PM   #4
deuce_roadster
deuce_roadster's Avatar
Could be the resistor wire is broken but making contact, heats up and gets intermittent. Try hotwiring the car to the coil and see if it continues to run with no missing.
Old 08-31-2019, 06:46 PM   #5
KiWinUS
KiWinUS's Avatar
Take off fuel cap
KiWinUS is online now   Reply With Quote
Old 08-31-2019, 07:24 PM   #6
jacob smith
I will do both at this point I will try everything
Ford
Old 08-31-2019, 07:25 PM   #7
daltonathomas94
I did hear a story of a guy building an engine. Got everything tuned up just right and it would cut out in a minute or so. Tore everything down 3 or 4 times to find an issue and nothing appeared. Finally, he popped off the gas cap and he was greeted by a whoosh of air into the tank and realized the cap wasn't vented right and made a vacuum in the tank pulling fuel back.
The smallest things can just slip by you some times.
Sent from my SM-G950U using Tapatalk
daltonathomas94 is offline   Reply With Quote
Old 08-31-2019, 09:08 PM   #8
Brian
Brian's Avatar
One more possibility is that the heat riser in the inlet manifold has blown; as it heats up, more and more exhaust dilutes the incoming charge. I have experienced this exact problem, took me months to diagnose; i was convinced it was electrical.
Old 08-31-2019, 09:37 PM   #9
jacob smith
Did it run fine when you had your foot of the gas but when you gave it gas the it would start to act up. Also does it make a sound like air going through baffles. It almost sounds like the sound that is made when you blow a horn but all you get is air thought the horn.
Ford
Old 09-01-2019, 07:13 AM   #10
KGS
KGS's Avatar
It could be something in the gas tank moving around
and blocking the fuel pickup tube, then releasing when
the engine is turned off.
KGS is offline   Reply With Quote
Old 09-01-2019, 09:10 AM   #11
jacob smith
No I cleaned the tank also
Ford
Old 09-01-2019, 03:29 PM   #12
Ggmac
Check for blocked exhaust .
Use a vacuum gauge and if it starts dropping slowly at first then steady drop till dies .
Old 09-01-2019, 06:58 PM   #13
jacob smith
I will do that also
Ford
Old 09-01-2019, 07:14 PM   #14
Yoyodyne
Yoyodyne's Avatar
Definitely sounds like that. Where is the air through baffles sound coming from when you hear it? Rear of the car?
Yoyodyne is offline   Reply With Quote
Old 09-01-2019, 07:59 PM   #15
jacob smith
Under the hood
Ford
Old 09-01-2019, 08:35 PM   #16
philipswanson
It's the nut behind the wheel...……………….. Just kidding.
philipswanson is offline   Reply With Quote
Old 09-01-2019, 08:44 PM   #17
jacob smith
It surely has driven me nuts trying to find the issue lol
Ford
Old 09-01-2019, 11:04 PM   #18
David Lien
Rag or water in the gas tank.
Long Range
David Lien is offline   Reply With Quote
Old 09-02-2019, 06:38 PM   #19
1948F-1Pickup
1948F-1Pickup's Avatar
^ What he said.
You've already eliminated my favorite (condenser).
1948F-1Pickup is offline   Reply With Quote
Old 09-02-2019, 06:41 PM   #20
Tinker
Tinker's Avatar
Engine gets hot, it starts to misfire....
Coil and condenser. New doesn't always mean good usually.
Get a vacuum gauge on it too...
