01-27-2019, 04:13 PM | #1 |
52 F1 brake question
Hi guys
Browsing through a mid fifty catolog, I came across a brake arm return spring. Since I could not find one on my truck, I referred to the shop manual without success. What is this spring? The catolog says if weak replace it allows continuous pressure on master cylinder causing overheating of brake fluid and brake troubles. Any one have a pic that shows it installed?
Thanks Andy 1952 F1 |
01-27-2019, 05:02 PM | #2 | |
Re: 52 F1 brake question
01-27-2019, 05:06 PM | #3 |
Thanks it that does look like the spring. But what vehicle is that?
Also do you know how it affects the master cylinder?
01-27-2019, 06:08 PM | #4 |
Weight of the pedal can have the same effect as riding the brakes . Most if not all should have a return spring
01-27-2019, 09:11 PM | #5 |
That’s how mine looks on my 48 F-1
01-28-2019, 06:53 AM | #6 |
01-28-2019, 07:57 AM | #7 |
Ok thanks guys. I’ll pickup one today.
