Old 09-20-2018, 02:54 PM   #1
1931flathead
Default head studs
I bought a new 6.0 head I been reading that you should have grade 8 studs and nuts
cause of the stock ones will not hold up to the higher compression cause they stretch out and don't keep there torque
1931flathead is offline   Reply With Quote
Old 09-20-2018, 03:13 PM   #2
CarlG
CarlG's Avatar
Default Re: head studs
Try ARP studs.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-20-2018, 03:20 PM   #3
1931flathead
I found them at vintage ford chrome moly
Old 09-20-2018, 03:40 PM   #4
JRN1967
JRN1967's Avatar
I bought mine from Snyder's they were the correct length, there's one just a little longer that's for the distributor wire clamp.
Part# A-6064/66-HD
JRN1967 is offline   Reply With Quote
Old 09-20-2018, 09:41 PM   #5
1931flathead
thanks I never seen them there most over looked them
Old 09-21-2018, 07:21 AM   #6
Big hammer
My engine builder said not needed, AER, Rich chuckled when I asked him.
get a bigger hammer tap done
Old 09-21-2018, 08:18 AM   #7
Dave in MN
Dave in MN's Avatar
Snyder's installation instructions suggest 55 ftlbs of torque for both their 5.5 and 6.0 heads. I have been torqueing to this amount for the engines I send out of my shop and have not been having any problems with any gaskets. JMO: You do not need chrome moly studs and nuts to hold torque at 55 ftlbs.
Good Day!
Dave in MN is offline   Reply With Quote
Old 09-21-2018, 09:43 AM   #8
MrBruce
MrBruce's Avatar
Good Day!
On a number of engines I've been using Chevy main bolts. They really look nice and they are suppose to hold more clamping load. They are the right length and my dad has built hundreds of engines with them.
MrBruce is offline   Reply With Quote
Old 09-21-2018, 10:27 AM   #9
Jim Brierley
ARP are the best, grade 8 are next but standard grade 5 are all that is needed. These can be bought at any good hardware store, or Snyders.
Jim Brierley is offline   Reply With Quote
Old 09-22-2018, 09:13 AM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
6.0 is NOT MUCH compression! Chiefs' NEW '49 Plymouth had 7.0 to 1 compression. Main thing is to RE-TORQUE the head nuts SEVERAL TIMES!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-22-2018, 11:01 AM   #11
1931flathead
Why take chance with 80 year studs and nuts been took off and on how many times for 40.00 you can have new one how many head gaskets can you buy for 40.00
Old 09-23-2018, 07:04 AM   #12
Dave in MN
Dave in MN's Avatar
I don't disagree with replacing old studs and nuts. I thought your original question was whether to use chrome moly or grade 8 studs and nuts. Most of us are saying the less expensive standard or "original style" studs and nuts are strong enough for the 6:1 head you plan to install.
Good Day!
Old 09-23-2018, 10:03 AM   #13
Dick Steinkamp
Dick Steinkamp's Avatar
Chevy's 365 HP 327 had 11/1 compression with standard (grade 5) head bolts. I think you're OK with standard on a 6/1 motor.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 09-23-2018, 11:39 AM   #14
1931flathead
For 16.00 for chrome Molly over stock studs are worth it to me just to be on the safety side
Old 09-23-2018, 01:11 PM   #15
holdover
As Said
"For 16.00 for chrome Molly over stock studs are worth it to me just to be on the safety side" Or any other head specific bolt from a quality vendor.
I would use new studs over 80+ yr old ones, not because they would be defective, but why take a chance. ARP is top quality for a price if you want to spend the extra money they will work fine. I use ARP bolts on any H-iPo builds I do, but bit of an over kill for a 6.0 model A head. The most important part is torque and re-torquing them. After all you are not building a nitro fueled supercharged monster...
holdover is offline   Reply With Quote
