03-14-2019, 02:05 PM | #1 |
Oil change
Hi guys
On my 39 coupe (no filter) I change oil every 1k. What’s suggested interval for 51 F1 with filter?
Thanks Andy 1952 F1 |
03-14-2019, 02:19 PM | #2 |
Re: Oil change
Here's a bunch of opinions.
https://www.fordbarn.com/forum/showt...nge+oil+filter |
03-14-2019, 02:40 PM | #3 |
Re: Oil change
Per the '48 owners manual every 2500 miles.
03-14-2019, 03:38 PM | #4 |
Re: Oil change
The interesting thing about this is that, while the oil change interval is stated as 2500 miles, the owners manual (at least for my 1951 car) calls out a chassis lube at every 1000 miles. I can't believe a truck (the way they were used) would be any more.
03-14-2019, 05:29 PM | #5 |
Re: Oil change
We're talking oil change not lub. job.
03-14-2019, 05:47 PM | #6 |
Re: Oil change
03-14-2019, 06:32 PM | #7 |
Re: Oil change
Interesting, I’ll go some what in between and change at 2k. Thanks
I also didn’t know lube every 1k. I’ll hit that more often- thanks
03-14-2019, 06:36 PM | #8 |
Re: Oil change
Anybody who is somebody knows the answer. Looks like adileo is finally somebody. 8^) Jack E/NJ
03-14-2019, 07:22 PM | #9 |
Re: Oil change
It seems to me that with the quality of today's oils, even 3,000 without a filter is not bad.
03-14-2019, 10:24 PM | #10 |
Re: Oil change
I do not run an oil filter as well and I’ve done 3k plus when on my LA Roadster trip - changed it in Pueblo, CO on my way back. That was probably closer to 4K actually ......
03-15-2019, 05:53 AM | #11 |
Re: Oil change
Seems that applying oil change intervals as set forth back when the oil was inferior to the oil that is available today should be taken into consideration.
03-15-2019, 11:22 AM | #12 |
Re: Oil change
Oil lab results will give the best indication of what it should be. Most of us just don't do it.
03-15-2019, 05:25 PM | #13 | |
Re: Oil change
The analysis showed the oil was in very good condition, no need to change it on any of their criteria. See attached.
'52 F-1, EAB flathead |
03-15-2019, 07:01 PM | #14 | |
Re: Oil change
03-15-2019, 08:22 PM | #15 |
Re: Oil change
They knew I'd changed it for the analysis, so what they meant was, "Run the new oil for 5000 miles and have it tested".
03-16-2019, 07:46 PM | #16 |
Re: Oil change
03-16-2019, 08:17 PM | #17 | |
Re: Oil change
"Some specialty or extended use oils with high levels of additives, or with metals such as zinc or molybdenum, may give falsely negative results. Examples include the Amsoil 'Signature' series , Redline oils, Castrol TWS and specialty, non API rated Royal Purple oils."
03-17-2019, 12:46 AM | #18 |
Re: Oil change
I run a 95% oil filter setup and still change oil at 1000 miles or less. I grease the steering components at half that. In my opinion oil and grease changes are cheap preventative maintenance.
03-17-2019, 02:41 AM | #19 |
Re: Oil change
On such machines, the more often the change the better. Selected option 1K is just great.
03-17-2019, 03:38 PM | #20 |
Re: Oil change
One of the benefits of modern oils is the detergents that keep dirt in suspension until removed by the filter. But with no filter I would run non detergent oil and change more often.
