Old 01-25-2019, 05:58 PM   #1
Sal
Default 6 volt electric motor repair
Does any one know where I can get my 6 volt electric heater motor repaired?
Sal is offline   Reply With Quote
Old 01-25-2019, 07:09 PM   #2
Mike in Mass
Mike in Mass's Avatar
Default Re: 6 volt electric motor repair
Hey Sal ,Add your city and State to your profile ,somebody might know a place right down the street .Mike
Mike in Mass is offline   Reply With Quote
Old 01-25-2019, 08:09 PM   #3
FortyNiner
FortyNiner's Avatar
It might be just as cost effective to replace the motor. Can you share pics?
Old 01-25-2019, 08:16 PM   #4
Charlie Stephens
Sal,
Suggest you add your general location to your profile so you get local repair services. Post what kind of heater you have (is it an ARVIN?) and maybe someone will know a motor that fits and is available. Plus pictures would be useful.
Charlie Stephens
Old 01-25-2019, 11:46 PM   #5
4dFord/SC
4dFord/SC's Avatar
Try flathead48 on this forum.
4dFord/SC is offline   Reply With Quote
Old 01-26-2019, 06:45 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by Charlie Stephens View Post
Sal,
Charlie Stephens
A quick search will show that Sal is located in Winter Garden, Florida and supplies his phone number also.
Old 01-26-2019, 07:00 AM   #7
Sal
Thank You all for Your replies, I will see if I can get some one to help me post pictures later. I'm not good with computers.
Old 01-26-2019, 12:02 PM   #8
Anteek29
Anteek29's Avatar
Mine needed the wires replaced but the most difficult part was removing the squirrel cage fan from the motor shaft. Had to use a propane torch and lots of Liquid Wrench.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 01-26-2019, 03:04 PM   #9
supereal
supereal's Avatar
C&G 800-266-0470 has them in their catalog. About $80, a fair price and probably less than having it rebuilt.
supereal is offline   Reply With Quote
Old 01-26-2019, 04:32 PM   #10
Paul Bennett
In my local area the motor repair people laugh at motors smaller than 2hp.
My HF might work but don't know your year/car. Last item on my 12v conversion I'm facing removal of my 6v heater fan to get access for shaft measurement of diameter/length. Some Mustang fans reportedly work. But I must remove the car's engine to get close to the thing from inside the engine bay. Before you choke, I'm going to remove the engine for replacement anyway. Unless someone kindly shares shaft diameter and length. '50M
Paul Bennett is offline   Reply With Quote
Old 01-26-2019, 08:08 PM   #11
B-O-B
B-O-B's Avatar
Grainger used to carry small DC motors
B-O-B is offline   Reply With Quote
Old 01-27-2019, 11:45 PM   #12
40ford
40ford's Avatar
Mid Fifty has a 6 volt heater motor. Part # 6V-1924
40ford is offline   Reply With Quote
Old 01-28-2019, 04:22 AM   #13
RKS.PA
RKS.PA's Avatar
As supereal notes above C&G sells a replacement 6 volt that I used in my '47. I had to cut the shaft a bit, but otherwise it was a direct replacement for the original. Works really well. Not sure why my original quit....worked fine before I removed the heater to rebuild the engine and transmission, but when I put it back in the car....nothing!!! (Must have been the heater gremlins in my storage box???
RKS.PA is offline   Reply With Quote
Old 01-28-2019, 05:27 AM   #14
FortyNiner
FortyNiner's Avatar
Napa sells a 6 volt motor, #655-1021, for about $36 USD. Worked great for my 3 door heater.
Old 01-28-2019, 08:08 PM   #15
leon bee
Thanks for that, got one on the way.
leon bee is offline   Reply With Quote
Old 01-28-2019, 08:48 PM   #16
FortyNiner
FortyNiner's Avatar
For those converting to 12 volt, the NAPA version is #655-1020.
Old 01-29-2019, 02:11 PM   #17
Sal
Thank You all for the replies, tried C&G they said these motors are discontinued. Got to pick up Hemmings and find a rebuilder unless any one knows one.
Old 01-29-2019, 02:19 PM   #18
meric42
meric42's Avatar
I think that you'll find that the motors tha C&G carry are only the 2 wire variety so will work in Ford heaters but will not change direction the same way as the 4 wire Motors do i.e. by reversing the field winding polarity.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 01-29-2019, 05:46 PM   #19
FortyNiner
FortyNiner's Avatar
You are correct, they are two wire motors. I could not find a reversing 6 volt in the right size.
Old 01-29-2019, 07:47 PM   #20
russcc
Hey Sal, what state are you in. There is great old time electric motor rebuilder here in MA.
